#1
Posted 17 October 2011 - 10:30 AM
My solution so far has been to reset the dial to final spin a couple times, until it works. So since it does sometimes do the fast Final spin when I do this, the washer obviously has the ability to still do Final spin and drain, it just doesn't do it most of the time.
I opened the bottom of the washer and checked the hoses and pump for clogs where they are connected. I didn't find anything, which I suppose makes sense since the washer is able to occasionally do Final spin and drain, just not most of the time.
Please help! I don't know what to check next. :S
#2
Posted 17 October 2011 - 11:08 AM
is it Pumping out all of then Water first ?... it won't do a proper Final spin
#3
Posted 17 October 2011 - 11:20 AM
#4
Posted 17 October 2011 - 11:47 AM
#5
Posted 17 October 2011 - 12:58 PM
#6
Posted 17 October 2011 - 07:26 PM
#7
Posted 17 October 2011 - 07:32 PM
is it Pumping any more water out when you set it to Final Spin ?... don't understand why if I reset it to Final Spin a couple times after the first time,
it will eventually do the high speed spin?
Is the Door locked ?
Is the Door really locked ?
While the Door is locked, remove the Washer Power Cord from the Wall Outlet.
Can you then Open the Door right away,
OR only after a few minutes ?
#8
Posted 17 October 2011 - 07:48 PM
- kdog likes this
#9
Posted 17 October 2011 - 07:57 PM
The door was locked - the Door Lock light is on and I cannot open it. While it was locked, I pulled the power cord, and the door can open right away.
#10
Posted 17 October 2011 - 08:01 PM
Valuable additional info! This indicates a bad door latch assembly ==> http://www.repaircli...ber=GLTF1670AS0
Replace it before the speed control board.
- kdog likes this
#11
#12
Posted 17 October 2011 - 08:21 PM
This is interesting, because I had just replaced the door latch with a new one a couple weeks ago, before all this started. (I thought I had a faulty door latch at the time, when in fact the rubber lining was simply not secured properly). In any case, I tried connecting the door latch both old and new as in the video, but the door will still open immediately after I unplug the power. Unless I am connecting it the wrong way, and I don't see any other way it can be connected, I'm not sure what is going on.
#13
Posted 17 October 2011 - 10:08 PM
#14
Posted 17 October 2011 - 10:13 PM
How would you do that ?can the wires of the door latch assembly only connect in one direction
Doesn't it just plug-in ?
#15
Posted 18 October 2011 - 07:17 AM
#16
Posted 18 October 2011 - 10:34 AM
...after a minute or two in the Spin Cycle ..... door can be opened immediately after unplugging the power -- which you seem to indicate is not right.
OR it may be a bad Controller (or it's connections)
#17
Posted 19 October 2011 - 11:11 AM
#18
Posted 26 November 2011 - 09:23 AM
#19
Posted 26 November 2011 - 09:52 AM
0 members, 1 guests, 0 anonymous users
