I'm going to call this one "Something BIT ME!". Not literally but I did get shocked today for the first time in a long time. I ran across a range that the oven was not heating. Pulled the ignitor and saw that the wires were charred and unattached behind some porcelain wire nuts. No big deal right? So after getting the whole bottom of the oven out to gain access to what was left of the wires I saw that the insulation was black and charred but not so bad, just looked like a wire burned up. I pulled the old wires out and ran some new ones around the back of the range, re-assembled, turned it on and nothing. So at my splices I was going to check for power and zap!!! When I grabbed the wires it shocked me. ??????? (insert profanity here) I couldn't believe what had happened. I took out my meter and sure enough from the insulated wire to ground I was getting 100-110v. I propped up my meter and my leads to get my arms and hands out of the way and took a pic because I wasn't sure I believed it myself. Anyone else ever run into this?
I replaced the wires and that corrected the live insulation problem but the ignitor would never come on. I checked the voltage across the wires (one from the gas valve and one from the orange wire in the harness) and only got 44v. Any of this make sense? Also when I had the old wire in my hands I ohmed out the insulation to the wire and got ol on the meter. I'm confused about this one.
IMG_0820-2.JPG 189.9KB
16 downloads
