Dacor ERD30 Broiler Failure
8 replies to this topic
#1 robnw
robnw
  • 15 posts
Posted 21 October 2011 - 10:55 PM
The broiler in my Dacor dual-fuel range (ERD30) quit working. (I believe it might have quit after my daughter left the broiler on for hours, but I am not certain....) I hear a click in the oven after initiating broiling, but it never fires up. Other oven modes work perfectly, except that preheating is slow due to the lack of the broiler's participation.
Will you please tell me how to troubleshoot and fix the problem?
And, please be patient: I am an expert gynecologist, but a novice appliantologist. (I did, however, successfully repair two washers with your assisance, and I am most grateful!)
RobNW
Edited by robnw, 21 October 2011 - 10:57 PM.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 October 2011 - 12:02 AM
could be that the glow Ignitor is either weak, or not working at all.
Do you see the Broil Ignitor glow at all ?
http://www.repaircli...?R=154&N=755980
#3 robnw
robnw
  • 15 posts
Posted 08 November 2011 - 01:33 PM
No - Don't see any glow at all (broiler on, door open).
Sorry I missed this post.
Rob
#4 RegUS_PatOff
  • 33,588 posts
Posted 08 November 2011 - 02:33 PM
could also be broken..
may have to measure the volatge 120v AC across the Ignitor wires
#5 robnw
robnw
  • 15 posts
Posted 08 November 2011 - 03:46 PM
I dropped the igniter down... Where do I check the voltage? On the igniter, or at the other end of the wires? If the latter, how do I get to where they're attached?
Rob
#6 RegUS_PatOff
  • 33,588 posts
Posted 08 November 2011 - 10:14 PM
either end of the wires should have the same voltage
    Shōgun
  • Master Samurai Tech
  • 31,400 posts
Posted 09 November 2011 - 07:45 AM
Does the bake work? If it's out, too, then you may have tripped the overload behind the door lock assembly. This will happen if you broil with the door open, for example.
#8 robnw
robnw
  • 15 posts
Posted 09 November 2011 - 07:59 AM
Bake works. Controls seem to be working, too. Preheat is slow; I assume because the broiler is out.
I can't figure out where to check the 120 voltage: do I just test it at the element of the igniter as it exits the ceramic part? (The wires are heavily insulated in the oven, and I don't see any accessible terminals before the ceramic part of the igniter.) And, I don't know where the other end of the wires connect, as I haven't taken anything else on the over apart.
Rob
#9 RegUS_PatOff
  • 33,588 posts
Posted 09 November 2011 - 12:39 PM
check for 120v Ac at the BR Terminal on the Main Relay Board
