WJRR4170E1WW Not agitating
2 replies to this topic
#1 acadiel
acadiel
    Ikkō-ikki
  • Chief Appliantologist
  • 30 posts
Posted 22 October 2011 - 07:27 PM
I did a bit of Googling and looked around before posting this; just wanted to get a second opinion.
Heard a whining noise when the agitate cycle started on this.. not sure what was going on, so Googled and saw three things:
1) motor
2) transmission
3) the bell shaped thing that coupled the transmission with the agitator assembly
So, filled it up on a small load and let it start agitating. Hurried up and pulled the lid (my magnets must not be strong enough to fool the reed switch), and saw the agitator assembly spinning a little. Pulled the agitator off and did the same - saw that the bell shaped plastic assembly was moving back and forth.
The bell shaped plastic assembly freely moves left and right - I'm gathering it's supposed to be firm and not really spin too freely.
So, does everyone else think it's probably just the bell assembly as well being stripped off of the metal transmission post? Here's what I found (I've seen numerous part numbers for this, so not sure if it matters which ones I get...):
http://www.repaircli...R=154&N=1264702
Thanks!
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 23 October 2011 - 11:02 AM
the part you linked is the correct part and most likely what you need. remove the old one and have a look at it.
#3 acadiel
acadiel
    Ikkō-ikki
  • 30 posts
Posted 23 October 2011 - 03:10 PM
Yep, it was stripped. Paid a premium for the part locally ($18), but it's fixed now. The new one doesn't spin freely like the old one did.
You guys rock! :)
