Chilidog
time to replace, not repair
10 posts in this topic
There comes a time in every appliances life when it it simply time to pull the plug, bite the bullet and upgrade to a newer machine. That being said, it is time to replace the washer dryer set with a new set. She Who Must be Obeyed, has expressed an interest in a front loading washer. I have explained to her about the potential mold issues related to those machines, and our budget compared to the top end machines.
In any rate, for those of you out there who deal with front loaders on a regular basis, are there any models to avoid?
Thanks.
... are there any models to avoid?
GE (parts prices and repair info)
Frigidaire / Electrolux
Samsung (parts prices / availability / service info / complicated electronics)
stay with
Whirlpool / Maytag / Amana
LG
Speed Queen
multiple choice drop-down menus, etc
http://www.ajmadison.com/
I agree with reg except...
electrolux has some new units out (on the market approx. 2 years) that I have been very impressed with...
hardly have done any repairs on these with the exception of a few cosmetic issues...no motors/bearings/control boards...
not the cheapest ones out there but definitely the largest capacity...dryer is cavernous!
More related to the user - just remember to always use hot water (it's only a few gallons) and DO NOT overdose with detergent and additives (a few gallons of water only requires a dab of detergent). There is just no information assembled that focuses upon the owners of the machines that do use correct dosing etc.
Specifically...
HE (regular strength ) : (2) Tablespoons Per Wash
HE 2X (double concentrated) : (1) Tablespoon
HE 3X ( triple concentrated) : (1) Teaspoon
Just as a note, brand name on the front (at least in the US) means little.  Maytags are all Whirlpools now, some were Samsungs.  Some Whirlpools/GE/"insert name here" are or were fridigaire built and most Electrolux I've seen are Fridigaire based. All Kenmores are someone elses.
Question really is who actually made it...Many Whirlpools seem to by Bosch built, or at least the same 3rd party un-named manufacturer. Example: Ever see a CAN-AM branded appliance?  You never will but they make dryers for other name brands.  It is hard to tell from the consumer end what you are getting, those of us who work on these can often see common internals that give clues,( or coded in the model #s in Kenmores).
---Whirlpool---  (110.xxxxxxxx as Kenmores) I'm not very confident in anything whirlpool right now as I've seen a bunch of rear bearing failures (death if out of warranty) in very young whirlpool and maytag machines; as in under 1 yr young in many cases.  In several models also.  The new top load design is also not expected to last long either by most of us.
---LG---Generally I like these and I have seen few major issues with LG machines, a few sensor related things and a few leaky valves.  LG makes some Kenmore also - look for "796" as the prefix of the model#) As a brand however LG doesn't have a long history in the US in washers so time will tell
---Samsungs --- (401.xxxxxxxx model # if Kenmores) I have also seen a few probs with them but nothing major.
---Frigidaire/Electrolux--- (417.xxxxxxxxx if Kenmore) Older design frigidaires had a decent rep and at least a decent warranty, modern ones are 1 yr like everyone else.  Electrolux seems to like to apply a gadget wizard to their design team to attach little touches like retracting main knobs and one push self opening dispenser drawers.  I've changed more than a few of the drawers due to broken or bent plastic bits in the spring system, it requires an entire drawer and valve asm on many units - all for a $.0005 piece of plastic.
The Whirlpools/Maytags that are built in Mexico are inferior junk. Main bearing failures in 6 monthes or less. If it has "Made in Mexico" on the data plate, do not buy it.
.., are there any models to avoid?
post "considered" model number here for opinions
The new Whirlpool Duet front load washers are a completely new design and they are assembled in Clyde, Ohio. PLEASE give them a chance to prove themselves before you tell everybody not to buy them.
