Refrigerator Problem GSS22JEREBB
Freezer coils
19 replies to this topic
#1 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 24 October 2011 - 07:44 PM
We installed a new freezer defrost heater that we purchased from your site. We don't know if this freezer buildup is normal or not. Thanks!Attached File  IMG00295 (640x480).jpg   179.53KB   9 downloads
    Shōgun
  • Master Samurai Tech
  • 31,193 posts
Posted 24 October 2011 - 07:58 PM
Re-check your wiring and connections-- sumpin ain't raht there.
Did you replace the defrost thermostat at the same time?
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 October 2011 - 08:00 PM
... was the "old" Defrost Heater bad ?
How's the MotherBoard and Thermistors ?
#4 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 24 October 2011 - 08:41 PM
Yes the heater was bad. My husband talked with you about it before. We didn't replace the Thermistors or Thermostat....we don't know about the motherboard. But that build up is not normal?
#5 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 24 October 2011 - 08:52 PM
where can we find the defrost thermostat.
#6 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 24 October 2011 - 09:19 PM
The defrost thermostat is clipped to the top of the coils and one of the heater wires goes through it, but if you have just replaced the heater, you should now have 2 heaters located at different heights in the coil as the new part is subbed with a pair of heaters
The Model Number posted is incomplete, but it appears to be THIS one (The 140 degree type):
Video in Link
http://www.repaircli...ber=GSS22JERFCC
#7 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 24 October 2011 - 09:28 PM
Would this be it? Does it look normal?
#8 kdog
    RoughShod
  • 7,474 posts
Posted 24 October 2011 - 09:34 PM
That is the heater connection. the T'stat is at the top of the coils, but they don't "look" normal or abnomal, they fail electrically (need meter) - see the video on the Part Link above for testing info.
And fetch the rest of that Model Number
#9 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 29 October 2011 - 02:50 PM
We replaced the thermostat. How long until we see results?
#10 kdog
    RoughShod
  • 7,474 posts
Posted 29 October 2011 - 02:54 PM
Did you test the existing one ? Still didn't catch that complete MODEL NUMBER
Ten Commandments for Reading Appliance Model Numbers :)
#11 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 29 October 2011 - 03:09 PM
Model GSS22JEREBB
We didn't test it, but replaced it anyway since we had trouble with it.
#12 RegUS_PatOff
  • 33,588 posts
Posted 29 October 2011 - 03:53 PM
.. How long until we see results?
a Fridge starting at room temperature, could take 24 hrs or more to reach optimum temperatures
Starting with a completely defrosted Evaporator Coil, could go for a few weeks without causing any air-flow problems
#13 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 05 November 2011 - 04:46 PM
Okay so we've replaced the thermostat and the heater, starting from scratch and this is what it looks like now. What else is the problem?
#14 RegUS_PatOff
  • 33,588 posts
Posted 05 November 2011 - 05:36 PM
it looks better...
hard to tell on GE's
Does the Freezer / Fridge cool OK now ?
#15 kdog
    RoughShod
  • 7,474 posts
Posted 05 November 2011 - 05:43 PM
:eyefinger:
Still not seeing the pair of heaters, only see wiring running to one heater at the bottom of the coils, shouldn't there be a second one about halfway up ??
http://www.repaircli...ber=GSS22JEREBB
 for replacement detail :
#16 RegUS_PatOff
  • 33,588 posts
Posted 05 November 2011 - 05:55 PM
looks like (1) dual Heater assembly
#17 kdog
    RoughShod
  • 7,474 posts
Posted 05 November 2011 - 06:00 PM
Model GSS22JEREBB
Edited topic title
#18 kdog
    RoughShod
  • 7,474 posts
Posted 05 November 2011 - 06:09 PM
My mistake - I assumed the "dual heaters" were to be installed at different levels of the coil as they are in many other units, but they don't mention that on instruction sheet.
#19 Jill Hahn Leardini
Jill Hahn Leardini
  • 8 posts
Posted 05 November 2011 - 08:59 PM
It is cooling okay. But we usually have trouble after about 2 weeks when the frost gets really bad. We looked on your site and it said something about a Defrost timer. I looked on the diagrams of our unit and we can't find it. Do we have a defrost timer? If not, can we force it into defrost mode so that we can see if that is working. We don't think it is defrosting. Thanks for all the help.
#20 RegUS_PatOff
  • 33,588 posts
Posted 05 November 2011 - 09:33 PM
no mechanical Defrost Timer on that GE model.
Defrost is controlled by the MotherBoard.
No forced Defrost Test function on that GE model.
On the MotherBoard, you'd have to jumper
J9 Defrost Heater
to
J11 Line
for a few minutes until it's defrosted.
it could also be that one (or more) of the Thermistors is bad.
http://fixitnow.com/...ed-thermistors/
