Frigidaire double oven FEB398WECD F4 error code
7 replies to this topic
#1 Tim M
Tim M
    Kohai
  • Scholar of Appliantology
  • 324 posts
Posted 25 October 2011 - 09:26 AM
Top oven takes forever to heat. Sometimes shuts off and shows F4 code.
Old temp probe shows 1.07 K Ohms
#2 Tim M
Tim M
    Kohai
  • 324 posts
Posted 25 October 2011 - 10:30 AM
Of course it seems to behave once I've got it out of the wall.
#3 Tim M
Tim M
    Kohai
  • 324 posts
Posted 25 October 2011 - 10:37 AM
OK. So even they said the problem is intermittent. I'm guessing F4 does mean a shorted sensor, but it seems to test OK. The codes I'm looking at may not be for this model. I'm tracing the wires and they LOOK okay.
#4 RegUS_PatOff
  • 30,201 posts
Posted 25 October 2011 - 10:43 AM
... I'm guessing F4 does mean a shorted sensor,
that's all I could find...
Did you try a new Sensor ?
(price is right)
(may be intermittent)
OR may be a bad Controller ...
http://www.repaircli...R=154&N=1015027
I have a wiring diagram, but doesn't look like much help
#5 Tim M
Tim M
    Kohai
  • 324 posts
Posted 25 October 2011 - 10:48 AM
Reg_US,
So glad to hear from you as always. I brought another sensor with me, but since I have to cut the wires since they changed the design, I was hesitant to install it. I switched the two existing sensors, but since it is an intermittent problem, and they are both behaving fine now, who can tell. I guess I'll bite the bullet and install the new one, but I don't want to be called back to re-diagnose. I guess I have plenty of time before Thanksgiving for the problem to show up again if I am wrong.
Tim
#6 RegUS_PatOff
  • 30,201 posts
Parts List & Wiring Diagram
5995334116.pdf
#7 kdog
    RoughShod
  • 7,428 posts
Posted 25 October 2011 - 01:24 PM
When the issue is intermittent like that it often means a connector is corroded in the harness, or the wiring somehow burnt/loose/damaged (sensor harness). Can be effected by heat and use of oven
#8 RegUS_PatOff
  • 30,201 posts
Posted 25 October 2011 - 01:34 PM
has Self-Clean been done lately ? :nono:
