#1
Posted 26 October 2011 - 01:58 PM
Looking for a bit of help.
I have a GE model PSS25MGNAWW and I performed the self test and it showed a failed thermistor in the freezer. I got test results on the display as freezer P and on the FF side I had 1,2,3,4 and then O on the freezer which O being failed ff #5. So it went like this P1,2,3,4,O 5 and a couple beeps. Which is a failed #5 thermistor. I replaced the thermistor and re-set the unit and re-tested and same thing O #5. So, I thought I had a bad part so I tried another brand new thermistor and same results. I am stuck and dont know what to do. Can anyone offer any help? The unit seems to be running fine but I hate knowing it is saying something is not right and want to correct the issue if I can.
I tested the brand new and original thermistor in a cup of cold ice water and let it sit for 5 minutes and I got a reading of 15.5 on the multimeter. Is that in the passing/good range? All 3 thermistors (1 original 2 brand new) read this on the multimeter. Leads me to think the original one was not bad but the system said it was.
Thank you for any help you can provide.
#2
Posted 26 October 2011 - 09:57 PM
The Thermistor Test numbers may have changed when they changed MotherBoard part numbers
#3
Posted 27 October 2011 - 04:43 AM
ps....I agree with Reg, the board is used on a number of different fridges. Just curious, where and how did you locate the #5 thermistor.
Edited by DurhamAppliance, 27 October 2011 - 04:48 AM.
- Samurai Appliance Repair Man likes this
#4
Posted 27 October 2011 - 07:58 AM
may no longer apply / replacement MotherBoard has been redesigned..; Just curious, where and how did you locate the #5 thermistor.
from 31-9072
Thermistor test sequence is:
1. Fresh food top thermistor
2. Fresh food bottom thermistor
3. Quick chill thermistor (displays 0 if unit is not equipped with Quick Chill option)
4. Evaporator thermistor
5. Freezer thermistor
#5
Posted 27 October 2011 - 01:32 PM
So, when I run the test I get P1,2,3,4,O5 followed by a couple beeps. So, a failed thermistor on #5 (freezer).
The unit say's it is not working but tried 2 brand new thermistors and it still said it was not working.
Does anyone know what the next step is to figure out why I am getting this fail on the freezer thermistor? Could it be the motherboard is bad on that thermistor?
Thank you for any help you can offer.
-David
#6
Posted 27 October 2011 - 02:14 PM
. . . . original M/B WR55X10174
replacement M/B WR55X10942
#7
Posted 27 October 2011 - 02:40 PM
#8
Posted 27 October 2011 - 03:42 PM
where is the Quick Chill Thermistor located ?I only see (2) Thermistors in the Freezer and (2) in the Fridge
#9
Posted 27 October 2011 - 07:36 PM
I have no clue. I am just going off the tech guide and that I do have the quick chill option. But I do get a O5 reading so failed freezer thermistor and I have tried two brand new thermistors and same fault code even with a brand new thermistor installed.
Can you offer any advice on what I should do to fix this issue I am having?
#10
Posted 01 November 2011 - 08:25 AM
Thank you for your time and advice.
#11
Posted 01 November 2011 - 10:00 AM
#12
Posted 01 November 2011 - 11:02 AM
I'll also offer something of which I'm really not sure but I will fall back on Mr Spock's implausibility quote and suggest it anyhow. The last four pins on your board's J1 connector is for "Model Select." Based upon the thermistor/ quick chill discrepancy as noted by GMF RegUs, it could be something going on with the connector or board at this location. Just a wild guess and making assumption that "model select" does what its title suggests.
Edited by DurhamAppliance, 01 November 2011 - 11:31 AM.
#13
Posted 02 November 2011 - 10:20 AM
..........before board...
.....after board................Logger copies...... customers lovem
- Samurai Appliance Repair Man, kdog and DurhamAppliance like this
#14
Posted 02 November 2011 - 08:09 PM
#15
Posted 03 November 2011 - 09:19 AM
FAQs | Parts | Memberships | Consultations | Repair Videos | Newsletter | Beer Fund | Contact
#16
Posted 03 November 2011 - 09:54 AM
#17
Posted 04 November 2011 - 08:23 AM
#18
Posted 04 November 2011 - 08:28 AM
If it doesn't fix the problem, return it for a refund!
Also tagged with one or more of these keywords: thermistor, ge, PSS25MGNAWW
