Kitchen Aid Dishwasher KUDM25SHBL1 Panel Lights Flashing
9 replies to this topic
#1 ciucca
ciucca
    Ikkō-ikki
  • 21 posts
Posted 15 November 2005 - 07:43 AM
My DW started exhibiting the following behavior. In the middle of a normal or scrub cycle the unit will stop and the button and cycle light (wash, rinse,...) will blink in unison. The blinking is a pattern of long and short pulses. Is this some error code? I can clear the condition by cutting the power to the unit for around 5 minutes and then switch the breaker on everything is back to normal for a few wash cycles and then it starts again.
From reading the technical reference sheet in the washer, it seems to imply that the blinking is a bad keypad. From searching this board it appears that the problem is either the control panel or the "electronic control Assembly".
Since these parts are expensive and i don't wish to purchase both, does anyone from the description have an idea which is more likely? Also to the long and short pulses mean anything? like a morse error code maybe. I didn't see anything in the technical spec sheet.
Thanks You
Another Happy Kitchen Aid Dishwasher owner
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 15 November 2005 - 08:16 AM
From the sound of what is happening and looking at your tech sheet seems like a touch pad may be sticking....if the parts are ordered thru this site they can be returned, less shipping costs, if it does not solve the problem....;)
#3 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 15 November 2005 - 08:19 AM
Here is a SERVICE POINTER also for the KA DW's, however it does not list your model number...
#4 jjdonohue
jjdonohue
  • 2 posts
Posted 15 November 2005 - 01:00 PM
Hi
I had the same problem with a kitchenaid dishwasher of similar part number.  It was about 4 yrs old at the time.   it turns out the entire control panel had to be replaced because the dc-dc converter could not tolerate fluctuations in voltage from the house.  In my neighborhood, house voltage is not a steady 120 volts.   Subsequently, the control panel eventually started exhibiting the behavior you are describing.   My panel was under warranty so that was replacable, but I still had to pay labor i think.
Hope that helps
#5 ciucca
ciucca
    Ikkō-ikki
  • 21 posts
Posted 16 November 2005 - 04:17 AM
Thanks to all who answered.
My plan is to replace the Control assembley first and then if that doesn't work the control key pad.  It may cost my as little as $100 or upto $250.  I guess that is ok for a 5 year old dishwasher. It's still less than the $1000 :yikes: for the new one my wife would be willing to replace it with.  I will post the results so hopefully it can help someone else in the future.
#6 ciucca
ciucca
    Ikkō-ikki
  • 21 posts
Posted 26 November 2005 - 05:59 AM
Update.
It turned out to be the Control Panel. I replaced it and it has been working fine ever since.
    Shōgun
  • Master Samurai Tech
  • 30,731 posts
Posted 26 November 2005 - 06:21 AM
Thanks for letting us know. :dude:
#8 Bonedoggie
Bonedoggie
  • 6 posts
Posted 05 September 2006 - 05:45 PM
I have the same symptoms. Is it agreed that it is best to replace the electronic control first?
#9 Bonedoggie
Bonedoggie
  • 6 posts
Posted 01 October 2006 - 12:05 PM
I am having this same problem. I have ordered this -
http://www.repaircli...?R=154&N=830982
Is this the correct part to replace? Is it an easy job, and could anyone provide a link to any documentation that would help me along?
#10 Bonedoggie
Bonedoggie
  • 6 posts
Posted 13 October 2006 - 08:08 AM
Well, no one would reply to my query, grasshopper or samurai, so I ordered both parts. For others who don't get answers to questions like mine, I replaced the keypad first, and the problem still occured. I then removed the new keypad, replaced the control unit and installed the original keypad. Everything has worked fine since, and I am returning the keypad to repair clinic. It was a very simple job.
