Maytag MDE3000AYW clothes dryer: Underlying cause of door switch failure?
Drum does not turn Not working
1 reply to this topic
#1 Clouds-Wind-Mist
Clouds-Wind-Mist
  • 2 posts
Posted 28 October 2011 - 12:38 PM
Dryer stopped operating (no drum rotation). Door switch was faulty (no power on the circuit that sends current to the dryer's functional parts).
I replaced the faulty door switch. Now have high voltage at the motor (as determined with a voltage detector) but dryer still does not operate. Start switch is functioning OK. Lighted controls on panel are functioning OK.
Other than a bad motor, what else could be the problem? Could a short somewhere have caused the door switch to become fried?
Is there something I can check with a voltage detector and/or volt meter?
Note that I am too puny (seriously) to remove the motor.
    Shōgun
  • Master Samurai Tech
  • 30,042 posts
Posted 28 October 2011 - 07:07 PM
If you're getting 120vac (nominal) to the motor at the correct windings but the motor no workee, then i think you're dealing with an open neutral somewhars either inside the dryer or at the dryer's power supply. If it were a gas dryer, checking the outlet for an open neutral would be as easy as plugging in a lamp. Not so straightforward in a 240vac circuit like on your dryer but it can still be done with a little understanding of the dryer power strip anatomy and using a lamp with alligator clip attachments.
