Replace door seal on Subzero 532
12 replies to this topic
#1 tdaugirdas
tdaugirdas
  • 3 posts
  • Flavorite Brew:Pacifico
Posted 28 October 2011 - 02:51 PM
What steps are involved in replacing the door seal on a subzero 532 (side-by-side) - refrigerator door seal? Are tools needed or does it just pull out and get pressed in. There is no vacuum when the door shuts and there is moisture and/or frost on the middle back wall.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 28 October 2011 - 05:36 PM
Only tools needed are a 1/4" nut driver and some patience....
make sure the defrost drain is clear to restore suction.
#3 tdaugirdas
tdaugirdas
  • 3 posts
Posted 29 October 2011 - 10:50 AM
Thanks for the reply!!
I don't see any nuts/screws holding in the door seal. Do you just pull the old seal off? The drain hose from the back wall to the pan at the bottom of the fridge is clear.
On what do you use the 1/4" nut driver?
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 29 October 2011 - 11:50 AM
Peel back the inside edge of the gasket and you should see a thin metal retaining strip, held in place with what will seem like 1000 1/4" screws...
#5 tdaugirdas
tdaugirdas
  • 3 posts
Posted 29 October 2011 - 02:12 PM
Ouch!! So - how do install the new one - after removing the old one? Is there some trick to screwing back the retaining strip with the new gasket?
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 29 October 2011 - 05:50 PM
Yeppers the trick is....wait for it...the aforementioned patience.
old strips must be reinserted in the groove on the new gasket...take yer time and work in a se@tion at a time while inserting a screw loosely here and there to keep it in place.
when you open the new gasket, it will be a wrinkled mess...give it a hot bath in the tub and then lay out flat to reform before reinstallation
#7 bpaulwhite
bpaulwhite
  • 2 posts
Posted 27 March 2012 - 07:52 AM
Anyone have any experience with Supco replacement door gaskets?
#8 RussTech
RussTech
    Kohai
  • 302 posts
  • Flavorite Brew:Heineken
Posted 27 March 2012 - 10:20 AM
I use heat guns, vasoline, and a hot bath in the kitchen sink.
#9 RegUS_PatOff
  • 30,205 posts
Posted 27 March 2012 - 10:37 AM
Yes, but what about the Door Seals ? :moondance: :whistling:
  • 24,228 posts
Posted 27 March 2012 - 09:20 PM
I like to put the gasket in the dryer on medium heat while removing the old gasket. Some other fine pernts of zen gasketology technique here ==> http://fixitnow.com/...et-replacement/
#11 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 27 March 2012 - 09:27 PM
Last SubZero gasket I replaced required nothing but patience. It's surprisingly hard; you'll get the top right corner in and the bottom left corner will pop out. Then you'll get the bottom left one in and the top left one will come out. I ended up using the nut driver because my thumbs were getting tired.
For what it's worth, SubZero put an instruction sheet with that gasket that specified using WARM, not hot water, to soften the gaskets. If you use a hair dryer, they want it 12 to 18 inches away. Apparently the new ones are more sensitive; all my senior techs were telling me to put them into the bathtub with the hottest possible water.
#12 woftam
woftam
    Ikkō-ikki
  • Master Appliantologist
  • 28 posts
  • Flavorite Brew:red wine
Posted 27 March 2012 - 09:40 PM
On S/Z gaskets I smooth out and lay new gasket face down on floor. Up north I would give them a hot bath but down here truck is rarely cold enough to need too. Since liners are molded to door I completely remove retaining strips and old gasket. Install strips in new gasket on floor then loosely install 6 screws (1 top 1 bottom and 2 each side). Finish shaping gasket and install screws. Use heat gun if needed.
There is a huge difference between 10 years experience and one years experience ten times over.
#13 woftam
woftam
    Ikkō-ikki
  • 28 posts
Posted 27 March 2012 - 09:45 PM
Almost forgot. If OP has frost/moisture on back wall and not around door there are more issues than gasket. Cold control or system problem.
