bigbluediesel
Noisy GE - TFB26SPDABS
8 posts in this topic
First - I know better than to own GE appliances. All of my Whirlpool / Kitchenaid appliances are cruising along nicely. However, my brothers GE side by side (model TFB26SPD BS) is a beast. The evaporator fan is loud enough to hear from the next room. Would that be remedied by a replacement blade? A blade adjustment? New fan motor? I haven't pulled it apart, but it is a constant noise that has persisted for months - unlike my other brother's Samsung which was making icicles that grew into the fan until it stopped.
Another question - the filter clogged which starved the icemaker and the water dispenser. I put a new filter in and bled it through the water dispenser. Is there a trick to getting the icemaker to fire up again? I've turned it off and then back on hoping it would initiate a cycle. The tray is clear and water free. It is one of the replacements from repairclinic.com - not the original GE icemaker.
Thanks to all.
A new fan motor will soothe that savage beast...check the filltube to see if it is plugged with ice.
this happens sometimes when water pressure is very low (clogged filter?).
So is it bearing going out on the motor that makes it so noisy? I remember reading something about a fan blade mounting issue somewhere but I can't find it. Also, I just spent the last hour reading about how crappy the IM6 is. I read about how it is being "replaced" with the WR30X328 when stock is depleted, but when I search that number, I come up with a RIM300 icemaker replacement. Anyone have any experience with these?
Some GE SxS evaporator fan blades will ride up on the shaft over time and rub against the plastic cover.
Nobody has any experience with the RIM 300 icemaker?
Don't recognize that #, but the I/m they replaced the im6 with is pretty crappy in its own right.
on a positive note, it is non-electronic...
RIM300 is a Supco replacement icemaker. I guess you could say it's the generic replacement. Did you test the water valve and make sure the fill tube isn't frozen?
That's on the list of things to do when I get back over to his house. He's working 80 hour weeks so he hasn't been able to mess with it. Thanks for the info.
