Siemens Siwamat xb 861 not loading enough water in Coton program
#1
Posted 29 October 2011 - 03:03 PM
I got a Siemens Siwamat xb 861 from a friend and noticed that it takes very little water at the Coton program. Laundry looks like it is dry and the soap does not form bubbles. Whereas at the Rinse program, it fills nearly half the drum with water which means that it is not a water source problem.
Any help is much appreciated.
Ragy
#2
Posted 29 October 2011 - 04:34 PM
Have you checked the clothes during the wash cycle to see if they are dry?
www.eliteapplianceservice.org
#3
Posted 30 October 2011 - 03:20 PM
Clothes look like they barely get wet during the wash cycle, and soap does not seem to form foam. I noticed that clothes don't get perfectly clean after the wash cycle.
I am comparing to an old machine I used to have; under the same conditions, the old machine took more water, soap formed good foam, and clothes were cleaner.
I am just wondering, why this Siemens is taking this little, insufficient amount of water in the wash cycle?
#4
Posted 30 October 2011 - 03:30 PM
Screens could be clogged where the hoses attach or the valve itself may not be opening all the way.
Try changing the water temp. for the cottons cycle and see if you get more water.
#5
Posted 31 October 2011 - 03:28 PM
I don't think it is a valve problem, evidence is that the rinse cycle works fine. I notice that time is the issue, the period of time the valve opens to pull water during the wash cycle is very small, compared to my old washing machine and compared to the rinse cycle of the same machine. This might be related to some sensor issue that closes the valve quicly, I suppose.. I am not sure.
Also tagged with one or more of these keywords: siemens, water
