LG LRBC22544ST fridge/freezer combo no longer blowing cold air.
LG LRBC22544ST not blowing cold air
3 replies to this topic
#1 umoms
umoms
  • 2 posts
Posted 30 October 2011 - 09:53 AM
I have a LG LRBC22544ST fridge/freezer combo and the fridge part is no longer working. I tried to leave it unplugged overnight and it still doesn't work. It doesn't blow out any cold air anymore. The gauge in the fridge all say FFFFF. Any ideas what could be wrong? Is it something i can replace myself?
#2 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 30 October 2011 - 09:58 AM
i you open the freezer door and push the light switch closed do you hear the fan running?
#3 umoms
umoms
  • 2 posts
Posted 30 October 2011 - 10:04 AM
no it doesnt
#4 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 30 October 2011 - 10:25 AM
going to have to do some testing, either at the board (behind the appliance) or at the fan motor (behind the rear wall
inside of the freezer).
I suggest the board.
if you look closesly at the board once you remove the cover you will see a connector
that has lettering over it that says "FFAN" freezer fan.
with the door shut on the unit dissconnect the power to the appliance,
wait 3 minutes, reconnect power, and w/o disconnecting the fan connector take a reading on those 2 wires.
if you have 12-15VDC the fan should be running...if not then the fan is bad or theres a bad wire somewhere.
if you dont have 12-15VDC you have a bad board.
Also tagged with one or more of these keywords: LG, LRBC22544ST, not blowing cold air
