Kenmore Elite Model No. - 110.27032603
F1 Error
5 replies to this topic
#1 btbaker
btbaker
  • 5 posts
  • Flavorite Brew:ESB
Posted 31 October 2011 - 02:26 PM
We are getting an "F1" Error flashing on the display of our Kenmore Elite Model 110.27032603 washing machine. Can someone tell me what the correct fix for this would be? I've read several forums and seen several different answers.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 31 October 2011 - 03:14 PM
from the Whirlpool Kenmore 110.27032603 Tech Sheets W10026571.pdf
F
. 1
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
➔ Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
➔ If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked,
replace the machine/motor control.
#3 btbaker
btbaker
  • 5 posts
Posted 31 October 2011 - 03:38 PM
Thank you! I tried to look this up on the repairclinic.com, but can not find the Machine/motor control listed. And when you talk about the pressure hose from tub to Machine/motor control, do you mean the hose from the wall, or is this an internal component?
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,917 posts
  • Flavorite Brew:Killians Red
Posted 31 October 2011 - 04:16 PM
Nope, this is the air dome hose...runs from the machine control to the tub....allows the control to sense the amount of water in the tub.
disconnect this tube from the control and blow thru it...if it is clear, replace control.
#5 btbaker
btbaker
  • 5 posts
Posted 31 October 2011 - 05:03 PM
Thanks - I'm getting closer! Is there a step-by-step on any site you know of on how to get to the air dome hose and check it?
Also tagged with one or more of these keywords: F1 Error
