jkilgore34
Samsung refrigerator rf265aabp ice maker adjustment
5 posts in this topic
I need help adjusting the ice maker for a customer. She says the cubes come linked together so cube size is to large. How do I adjust it so it will make smaller cubes?
If anybody can post the service manual here from www.servicematters.com, it's covered in the service manual how to change the water supply volume on the display control board.
https://servicematters.com/secured/maytag-lib/docs/SAM0074.pdf
it is document # SAM0074.
If changing the water supply volume doesn't work, I would try replacing the icemaker and the water inlet valve.
Thanks for the reply. I cannot access the document through the link. When I click on the link it asks for username and password. Could you please walk me through it?
The link is to a service manual - it's kind of complicated to make the adjustment, only 2 ice levels are available - 85cc fill and 95cc fill, Initially the unit comes set for the 85cc fill and would have needed to be increased to be on the high setting.
Press and hold "Freezer" button and "Power cool" (the middle button on left, and upper on right) - hold them simultaneously for 12 seconds, and the control will enter an adjustment mode. The displays on the left side will show a code, and the display on the right will show a reference or adjustment segment. You want the number on the right to display "2" (one of the r/h keys will cause the number to change), once it shows "2" - the work the l/h keys to make the left display number show "0". Once you have these numbers displayed, do not input anymore and 20 or 30 seconds later, the control will store the setting and go back to normal display mode.
I might also point out that, while in the adjustment segment "2" (r/h number), the alternative choice for the l/h display would be "1" which would indicate the control is set for the high fill level; such as it is being a whopping 10 cc of water. Having the icemaker level could play a part as well - being tilted could allow water to pool in one end or the other
