Sign in to follow this
Followers 0
bugleg
Viking VUD141-SS leak
6 posts in this topic
Trying to fix a leaking VUD141-SS. Does anyone know of a service manual? The unit is leaking between the tub and the large grey plastic unit that is held to tub by lock ring on inside. I assume there is a O-ring in there but can't see how to access.
Thanks!
Can you post a picture so we know which part you are referring to?
Thanks for the diagram--the leak is between the tub and the part labeled Well (#36). I assume the o-ring (#47) has failed and will order a new one--but I can't see how to remove the well to replace it.
... held to tub by lock ring on inside.
Thanks--I had the ring off, but it still seemed captured by some connections and perhaps the pan itself--but I did spy what looked to be a block of styrofoam jammed under it...
Followers 0
