Duet Model #GEW9250PLO won't start but Sensing light comes on.
4 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 415 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 01 November 2011 - 07:13 PM
Duet Model #GEW9250PLO won't start but Sensing light comes on. Door switch, Thermal fuse, Touch panel, and moisture sensor all check out. All the usual lights come on when unit is turned on. When the "hold to start" button is pressed the sensing light comes on and then does nothing. Any help is appreciated.
Edited by richseattle56, 01 November 2011 - 07:34 PM.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,949 posts
Posted 01 November 2011 - 08:48 PM
Do you hear the motor relay clicking on the control board?
It could either be a bad control board, a bad motor or a bad thermistor.
This thread needs to be moved to the laundry topics.
Edited by Scottthewolf, 01 November 2011 - 08:54 PM.
Scott Wolf
#3 Scottthewolf
Scottthewolf
    Senpai
  • 2,949 posts
Posted 01 November 2011 - 08:56 PM
Also, a broken belt or a bad belt switch may cause the same problem.
Scott Wolf
#4 richseattle56
richseattle56
    Kohai
  • 415 posts
Posted 03 November 2011 - 09:37 PM
The belt was fine. Checked belt switch it was fine. Replaced Main board all is well.
Thanks for the help Senpai!
Rich
    Shōgun
  • Master Samurai Tech
  • 30,371 posts
Posted 07 November 2011 - 07:24 AM
Was this the board you replaced? ==> Control Board
