#1
Posted 03 November 2011 - 04:04 AM
#2
Posted 03 November 2011 - 05:21 AM
This appears to be the Maytag version of the Whirlpool Duet sport, I've had this exact same problem on two different Duet Sport washer and found the offending object stuck at that point and have been able to retrieve it by pulling the boot back and using a long skinny screwdriver to reach between spin basket and tub to remove object.
- Samurai Appliance Repair Man, kdog and Comstock_Services like this
Eureka, CA 95501
#3
Posted 14 November 2011 - 09:03 AM
#4
Posted 26 December 2011 - 06:32 PM
#5
Posted 26 December 2011 - 09:03 PM
- kdog likes this
Also tagged with one or more of these keywords: leaking, washer
How to fix a Maytag Neptune washer that leaks from the detergent dispenser
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 November 2011 - 08:34 AMShine a bright light under the main wash tub, then look inside and you will most likely see something, (like a small kids sock), stuck between the basket and the outer tub right where the inlet tube that you have circled in yellow enters the tub.
This appears to be the...
Read Full Entry →
