GE Monogram ZCG3100 Trash Compactor Motor shaking
motor trash compactor
3 replies to this topic
#1 Grahambeau
Grahambeau
  • 14 posts
Posted 03 November 2011 - 12:26 PM
My ZCG3100 likes to tease me that it might stop working but I eventually coax it back into service given the limited options.
This time it threw a curveball - the motor started shaking something fierce (I thought my Miele washer in the next room that was in the final spin cycle). I took the drawer out and lowered the ram to examine if there were any obstructions and screws missing and couldn't find anything (although I cleaned some stuff up in the area). I couldn't begin to see how the motor is attached although I haven't started taking things apart. The problem persisted. I repeated this process several times and just this morning, it seemed to stop (I may be imagining it but it does feel like it still is shaking a bit). I'm afraid the problem might get worse again and want to check to make sure it doesn't.
Is there a repair manual available for this model? Or how does one check on the mounting of the engine? Any help appreciated. Thanks!
#2 kdog
    RoughShod
  • 7,428 posts
Posted 03 November 2011 - 12:54 PM
Been a few years since I've seen one of these GE units (okay- many years), but they are fairky simple - motor mounts to a "transmission" - a reducing gear pinion box, which is likely where your issue lies - seems to me that you access this set up by removing a panel in the upper rear area
http://www.repaircli...r=ZCG3100TBB-01
#3 RegUS_PatOff
  • 30,262 posts
Posted 03 November 2011 - 02:00 PM
GE Monogram ZCG3100 made by Whirlpool
but I'm not sure of the service manual number yet
may be some bad gears / etc / kit
GE part $ 169
Whirlpool part $ 58
http://www.repaircli...R=154&N=1171705
#4 kdog
    RoughShod
  • 7,428 posts
Posted 03 November 2011 - 03:04 PM
31-3976 is the manual # - That "transmission" unit is common failure for these
Also tagged with one or more of these keywords: motor, trash compactor
