Bosch WAS24460UC Service manual
srjacob
  • Replies 4
  • srjacob
  • I think I can
I PMed you the manual for the WAS20xx model numbers which you thought doesn't apply. Turns out that IS the correct manual even for the WAS24XX models, document number 58300000129936.doc – 03.01.08.
  • 4 months later...
I think I can
Need the same manual please.
Added to Downloads section here ==>
