Maytag gemini MER6770AAB error code F1-1
#1
Posted 05 November 2011 - 01:55 PM
I have ruled out the upper and lower temperature sensors, as I have put an ohm meter on them both and they are within specs at cold oven temp.
This leads me to the clock control. My wife uses windex to clean the touch screen and I have read this can degrade the membrane causing it to short out. I have tried disconnecting the ribbon cables and hooking up my fluke to various endpoints on the ribbon cable while pushing the touch screen to tell what is working but I do not have a schematic to know which button would be where on the ribbon cable. So my questions are these:
1. Can I replace JUST the clock overlay to fix this problem?
2. Could it be a sticky relay that can be replaced on the control board itself?
3. Anything else I may have missed checking?
4. If I have to replace the clock control do I also need to replace the overlay?
Thanks, any help would be appreciated.
Pete
#2
Posted 05 November 2011 - 02:46 PM
I'm afraid that those symtoms are quite typical of a control failure, the overlay/touchpad is part of the control
http://www.repaircli...mber=MER6770AAB
Also tagged with one or more of these keywords: error, Maytag Gemini, MER6770AAB, code F1-1
