Whirlpool Duet ht M# WFW9400SW01 Problem
23 replies to this topic
#21 delawaredrew
delawaredrew
    Sōhei
  • 183 posts
Posted 30 April 2012 - 03:30 PM
A bad rotary encoder on User Interface (display) board or just a bad UI board can cause selection issues and explain weird code on screen, does wobbling knob around cause selection to jump around? Also pop the top off and look for cut or abraded wires going to UI and at CCU.
As for the lock; if lock is engaging, that usually means the pin switch is reporting the closed door and allowing the lock to throw. There is a second switch that tells CCU (Main Control) that lock is engaged, that would cause a door lock error if not functional. The more expensive thing is if the CCU isn't seeing the lock switches due to internal CCU error. I've seen both parts fail.
To answer your question : the CCU holds programming and cycle info in EEPROM, if that is corrupted your CCU is dead, or at least beyond reasonable repair.
Edited by delawaredrew, 30 April 2012 - 03:30 PM.
#22 MENINBLK
MENINBLK
  • 15 posts
Posted 12 May 2012 - 03:33 PM
I placed an order today for the Main Control Board (W10319813).
http://www.repaircli...ber=WFW9400SW01
I hope this will cause the laundry demons to eradicate.
I will let you know soon...
Pete...
Pete...
#23 MENINBLK
MENINBLK
  • 15 posts
Posted 17 May 2012 - 12:51 PM
Installed part today and it seems that the demons have been banished for now.
I am going to let Tsunade Hokage return to her laundry duties and see if she notices.
Enjoy the beer !!!
Pete...
Pete...
#24 Samurai Appliance Repair Man
  • 24,203 posts
Posted 17 May 2012 - 02:05 PM
Nice job, Pete! Domo for the followup report. Samurai wuvs a happy ending. :wub:
