Learn Circuit Fu, the ancient lost art of appliance repair…
Seashell
Frigidaire GLTF2940ES0 Front Load Washer Won't Spin
8 posts in this topic
My washer won't enter the fast spin. The door locks, the washer drains, everything but spin. When it gets to the final drain and spin it only drains, then goes to the slow tumble and turns off with 7 minutes left on it's clock. Any ideas?
... The door locks,
Any Error Codes ?
does the Door lock ?
Does the Door really lock ?
When it's trying to Spin, unplug the Power Cord from the Wall Outlet.
Can you then open the Door right away,
OR only after a few minutes ?
http://www.repairclinic.com/referral.asp?R=154&N=1531974
The door locks and I am not getting any error codes. I can hear the lock click in when I hit Start, and I can hear it unlock at the end. The washer doesn't even attempt to start the fast spin. I tried unplugging the machine to see if it would reset and it still does the same thing.
Reading: the essential skill for effective communications in Internet forums. :geek:
Point taken :thumbsup: I unplugged the machine when it should have gone into the spin, the door was able to open right away. I see the link you have above for the door lock part if you tell me that is what needs to be replaced.
yes
Thank you---I've taken the door lock off and have ordered a new one to be here Wednesday! Will let you know if all is good then---sure looks like it will be!
