Fridaire front load machine sucks in a little water then stops responding LTF2140ES0
drain fridaire wont run through cycles help LTF2140ES0
4 replies to this topic
#1 Darryl Schweitzer
Darryl Schweitzer
  • 1 posts
Posted 07 November 2011 - 08:26 PM
Hello my Fridaire Front Load wash machine model number LTF2140ES0 is not running through any cycles. When I set the dial and press start the door locks and it sucks in a little bit of water and then just stops. The door stays locked and the LED's all stay on but the machine itself doesn't do anything. When I hit the stop button it unlocks the door and won't drain or anything like that. I am wondering if this sounds like a problem which could be fixed easily or if its going to be more trouble then anything else. I have an older machine to take its place but the front load has water in it and I would like to know how to drain that. I really appreciate any advice I could get on the subject thank you in advance!
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 07 November 2011 - 08:44 PM
What happens when you manually move it to DRAIN/SPIN?
The last one I had that did the same thing was a faulty motor control board in the bottom of the machine.
Tech sheet should be found in the bottom taped to the side panel inside the machine.
Scott Wolf
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 1,709 posts
Posted 07 November 2011 - 09:12 PM
I would also check pump and dispenser door.
  • 24,207 posts
Posted 07 November 2011 - 11:46 PM
Get the tech sheet from behind the bottom front panel and try putting the machine into diagnostic mode. Do tell.
#5 RegUS_PatOff
  • 30,192 posts
Posted 08 November 2011 - 01:18 AM
... and the LED's all stay on
that may be an Error Code ...
http://fixitnow.com/...nt-load-washer/
