Frigidaire FDB956RBC1...dead
2 replies to this topic
#1 jayY11
jayY11
  • 1 posts
Posted 09 November 2011 - 12:19 AM
Been reading in here quite a bit and was pleased that I had taken all of your steps before I even found you. The breaker wasn't tripped, outlet works fine and nothing in the dishwasher wiring anywhere looks/smells/feels burned. I don't have a voltage meter to check that...
I'm guessing it's something in the control panel? It died last night, mid-cycle. I've got half-clean and half-yuk dishes inside AND there's about 2 inches of water in the tub -- meaning it lost power before it could drain. But you knew that.
Thoughts? And thankyouverymuch!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 November 2011 - 12:21 AM
http://fixitnow.com/...hwasher-repair/
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 09 November 2011 - 06:57 AM
I do not know ALL the steps you utilized. Make certain the power connections in the terminal box are good. Then check the door latch switch for continuity. Power goes to the door latch before it goes to the control board.
