whirlpool calypso m#gvw9959k02
5 replies to this topic
#1 bmmc
bmmc
    Sōhei
  • Chief Appliantologist
  • 107 posts
Posted 09 November 2011 - 10:39 AM
no mini manual with this washer.cannot remember how to access the appliance manual stash.machine is dead & throwing a c1 code.help please.
#2 DADoESTX
DADoESTX
    Kohai
  • 258 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 09 November 2011 - 12:44 PM
CI not C1.
Current, Instantaneous. A spike of 26 amps (or higher) detected at the motor.
#3 bmmc
bmmc
    Sōhei
  • 107 posts
Posted 09 November 2011 - 12:46 PM
so in all likelihood,bad motor?
#4 RegUS_PatOff
  • 30,197 posts
Posted 09 November 2011 - 12:47 PM
gvw9959k02
maybe
GVW9959KQ2
CA or CI Average Current Limit, OR Instantaneous Current Limit
If a status signal comes back from the motor controller that a current limit has been breached,
the unit will return to standby mode and display either “CA” for average current limit trip, or “CI” for instantaneous current limit trip.
Average current trip occurs if there is a 2-second average of current draw greater than 5.55 Amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.
➔ This may signify problems with the drive motor, thermal protector, or motor controller.
➔ Overloading the unit may cause this problem.
■ Press Stop/Cancel to clear the display.
Tech Sheet - 8530143
PM'd
#5 kdog
    RoughShod
  • 7,428 posts
Posted 09 November 2011 - 01:13 PM
Usual occurrance with these, is the boot seal around the U-joint leaks and water siezes up the mechanism and the motor binds
whip the washplate outta there and see if that isn't the case
http://www.repaircli...mber=GVW9959KL2
#6 bmmc
bmmc
    Sōhei
  • 107 posts
Posted 09 November 2011 - 01:18 PM
i'll check that.thanks for your help.
