FRIG GLTF2940ES1 WONT SPIN
2 replies to this topic
#1 prairiestr
prairiestr
    Kohai
  • Chief+ Appliantologist
  • 271 posts
  • Flavorite Brew:Jack
Posted 12 November 2011 - 02:37 PM
Ran diagnostic test, error code E47 appeared.
Removed door lock , PTC ohms at 1000 approx. Not shorted or open.
When in "Drain/Spin" pump is running,(noisey) counts down from 13min to 9min, then tub rotates left, right left, right till 7min then control shut off and beeps 3 times.(no water in tub)
Does this sound like a control problem?
Any help greatly apprieciated.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 12 November 2011 - 05:11 PM
usually any 4x error code is a bad Door Lock Assembly
The PTC ohms test is not definitive.
Try this,
While in the Spin Cycle, remove the Washer Power Cord from the Wall Outlet.
Can you then open the Door right away (bad)
OR only after a few minutes ?
http://www.repaircli...R=154&N=1531974
#3 prairiestr
prairiestr
    Kohai
  • 271 posts
Posted 13 November 2011 - 10:44 PM
Tried this test today, in spin/drain cycle ran 2min. unplugged washer, door opened right away.
That sounds like a fail for the door switch. Will replace door latch tomorrow.
Thanks for the help. :thanks:
