Whirlpool Refridgerator ES2FHAXSA00
ice not dispensing
8 replies to this topic
#1 NSXDRYVER
NSXDRYVER
  • 5 posts
Posted 13 November 2011 - 03:08 PM
after many days running on a generator from bad storms in my area,my ice dispenser no longer is,er well dispensing.
i'm kinda thinking that the generator may have hurt it, lever seems to be working,light goes on, little door opens then closes after you try it,but motor not trying to work. in need of the repair manual for some procedures or what i exactly need.
please help not good to all ways keep opening the door for ice.
thank you ,Gary
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
  • Flavorite Brew:Killians Red
Posted 13 November 2011 - 03:16 PM
Indoor ice dispenser? If so...remove the small panel midways down the freezer door liner.
check for 120vac at the inside two wires on the plug feeding the auger motor while a helper presses the door switch and the cradle.
if voltage is present replace the motor...very common..
#3 Tronicsmasta
Tronicsmasta
    Senpai
  • PipPipPipPip
  • 519 posts
Posted 13 November 2011 - 03:19 PM
Let us know how you made out... :)
[edit]
Edited by Tronicsmasta, 13 November 2011 - 03:39 PM.
It is never a bad thing to leave it to the professionals. Inexperience can lead to more damage or risk of injury. You can always call A&E Factory Service (1-800-905-9505), Sears(1-800-469-4663), or local service man you can trust (servicemagic.com).
#4 NSXDRYVER
NSXDRYVER
  • 5 posts
Posted 13 November 2011 - 05:54 PM
ok just checked and i'm not getting voltage on the two inner wires,but if i take resistance readings... pin 1 to 2 is 13 ohms,but pins 4 to 5 it reads 52 ohms.
on a WHIRLPOOL GS6NBEXRQ00 it says ...
Pins 1 and 2 = 10 to 15 Ω
Pins 4 and 5 = 220 to 270 Ω
is this the same as my motor,sure looks like it .
do you need to door closed to read this voltage?
and your saying the wires for pins 2 and 4?
#5 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 13 November 2011 - 05:56 PM
yes you will need to close the door switch to get voltage readings, as the power to the dispenser is interupted by the door being open.
#6 NSXDRYVER
NSXDRYVER
  • 5 posts
Posted 13 November 2011 - 06:04 PM
ok one more check, on mine pins 1 and 2 (gray wire and blue wire)are i believe is the motor windings, i do get 120v
thinking the pins 4 to 5 (52 ohms ) is my problem,can someone solidify this? what is this ?
#7 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 13 November 2011 - 07:00 PM
If you have 120v going to the auger(ice dispenser) Motor, and it is not turning then you need to replace the motor.
#8 NSXDRYVER
NSXDRYVER
  • 5 posts
Posted 13 November 2011 - 08:07 PM
ok guys
i found the problem...
took the motor out,and while it was on my kitchen counter i noticed water dripping out of it after about a hour. curious i let it fully drain out ,about a 14 cup of water.i fully dryed it out with a hair dryer ,and wholla ,it works again,it must of been all iced up not letting it move,works great!
Gary
#9 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
Posted 13 November 2011 - 09:13 PM
Nice! Thanks for the followup. I fear this may be a temporary fix tho...
Also tagged with one or more of these keywords: ice not dispensing
