bosch wfr2450 Axxis+ washer wont spin, how to get error codes?
bosch washer error diagnostic
5 replies to this topic
#1 bluedarter
bluedarter
  • 3 posts
  • Flavorite Brew:pale ale
Posted 13 November 2011 - 04:19 PM
My Bosch WFR2450 doesn't spin, in wash cycle the drum does not rotate. Fills with water then sits there. How do I get the diagnostic error codes?
Thnx.
#2 bluedarter
bluedarter
  • 3 posts
Posted 13 November 2011 - 06:33 PM
I figured out how to get the error codes, and the motor test fails with error 10. My guess is that it is the motor brushes. My husband and I took the back cover off the washer and the front kick panel, and he messed with the brushes but couldn't figure out how to get the brushes out. The washer is now working, but clearly the brushes need to be replaced.
How do we get the brushes out so that he can get new ones?
Thanks.
#3 Comstock_Services
Comstock_Services
  • 462 posts
Posted 14 November 2011 - 07:08 PM
double check that model number please, as it's not coming up for me. please read it directly from the model and serial number tag.
#4 bluedarter
bluedarter
  • 3 posts
Posted 14 November 2011 - 11:04 PM
http://laundry.manua...0_wfr_2460.html
Thanks anyway.
#5 RegUS_PatOff
  • 30,264 posts
Posted 14 November 2011 - 11:17 PM
it's a valid model number
#6 kdog
    RoughShod
  • 7,428 posts
Posted 14 November 2011 - 11:30 PM
Pretty good video, but gotta disagree with a few points in it - "All Electric Motors have brushes" - that couldn't be further from the truth, in fact MOST of the motors that we, as appliance people, deal with DO NOT have brushes.
Also the brush he extracted from the motor he said "Shows no Visible Signs of Damage" - to me, the end of it that contacts the commutator has a clear strip burnt into it where it was perhaps not making full contact. Since I do not (have not) seen very many brushes, it would look suspicious to me.
Also tagged with one or more of these keywords: bosch washer, error, diagnostic
How to replace the motor brushes in a Bosch WFR2450 Axxis+ washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 16 November 2011 - 06:54 AM
If your Bosch washer won't spin or tumble, or the motor makes weird growling noises, you may need to replace the carbon brushes in the motor.
Here's the part link to the replacement brush set ==> http://www.repaircli.../154740/1043249
And here's a...
Read Full Entry →
