Whirlpool dryer model WGD5900SW0 heats sometimes
dryer gas heat
3 replies to this topic
#1 Shal
Shal
  • 10 posts
  • Flavorite Brew:Oatmeal stout
Posted 14 November 2011 - 03:16 AM
Mostly it doesn't heat.
I've checked the thermistor and thermostat behind the back panel, and of course there's continuity (because sometimes it does heat).
The igniter always glows for a minute, even when it fails to flame-on.
When it fails to light, the normal "click" is accompanied by a rattling type of noise, sounds like a solenoid not pulling in to me.
It seems to follow the "Roger Rabbit rule" for lighting -- only when it's funny. Such as when I have it all pulled apart to try and diagnose it.
Sounds like I should invest in a new set of coils, at the minimum. My question is whether I should go for the whole gas valve assembly -- is it probable that the failure is at least partly a mechanical one (wear, friction, rust, whatever) in the valve rather than solely a coil weakness. Is there an inspection or diagnostic that would answer that (short of buying only coils, then eating their cost when it turns out I needed the whole assembly).
Secondary question: since the dryer is 10 years old, should I replace the igniter while I'm at it, just because they do age. What is the expected lifetime of an igniter?
#2 RegUS_PatOff
  • 30,273 posts
Posted 14 November 2011 - 04:09 AM
... igniter always glows for a minute, even when it fails to flame-on.
... "click" is accompanied by a rattling
http://www.repaircli...sp?R=154&N=3479
  • 24,333 posts
Posted 14 November 2011 - 08:51 AM
Yep, sounds like anudda case of bad gas valve coils. Very common repair. Easy and inexpensive, too.
#4 Shal
Shal
  • 10 posts
Posted 14 November 2011 - 02:40 PM
Thank you sensei and Host!
Since experience tells you that trouble with the mechanical parts of the valve assembly is unlikely, I will proceed with coils only.
Arigatō
Also tagged with one or more of these keywords: dryer, gas, heat
