LG FRONT LOAD WM2487HWMA INTERIOR LIGHT WILL NOT GO OUT
#1
Posted 15 November 2011 - 04:46 PM
#2
Posted 15 November 2011 - 09:01 PM
Press & hold both the SPIN SPEED & SOIL LEVEL buttons
Press the POWER button---and release all 3 buttons
Wait for the door to lock (single click sound)-----if the door does *not* lock------replace MAIN BOARD.
Look at the Control Panel---if all of the lights are *not* on/illuminated---replace the DISPLAY BOARD.
Press the START/PAUSE button the following number times to continue testing...
1--Tumble CW & Drain Motor Runs
2--Low Speed Spin
3--High Speed Spin
4--PreWash Valve
5--Main Wash Valve
6--Hot Water Valve
7--Steam Valve
8--Bleach Valve
9--Tumble CCW
10-Heater 3 Seconds
11-Circulation Motor Runs
12-Drain Motor Runs
13-Water Level Sensor/Steam
14-Steam Heater Test
My opinion is that the MAIN BOARD has failed.
Also---you can rule out the DISPLAY BOARD by removing the front CONTROL PANEL...
Remove the DISPLAY BOARD---and then reconnect the plugs (of the DISPLAY BOARD)---plug in the washer and while holding the Board in your hand---press the POWER button microswitch to "turn on" the washer---and then press the START button microswitch numerous times to rule out an intermittent START switch on the DISPLAY board.
If the washer begins a cycle (starts) intermittently---failed DISPLAY BOARD (microswitch)
Edited by john63, 15 November 2011 - 09:49 PM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 16 November 2011 - 11:28 AM
- kdog likes this
