4 diff. symptoms on icemaker no workee Whirlpool GS6NBEXRS00
5 replies to this topic
#1 bigbigtex
bigbigtex
  • 3 posts
  • Flavorite Brew:iced coffee
Posted 16 November 2011 - 05:00 PM
Where do I start? This icebox has been such a pain! I'll list out the problems and what I've tested so far.
Unit does not make or dispense ice at all. The temp in the freezer is 10-12 degrees.
1. No water fills the tray. I checked the water fill rubber hose with 2 feet of string and the line is clear.
2. I slidd the icemaker unit out and checked the control module with the T & H test (door flap AND light switch taped down and also not taped down). I got no movement, no sound, no nothing, either way.
3. On the LED ice level sensor test, light flashes when opening door. When I hold down the tab, the red light stays on solid.
4. Door ice dispenser is totally non-functional. It does not rotate the auger. When I press the ice dispense button, there is only a quiet clicking (like it is kinda trying to activate). The water flow in the dispenser is OK. I did not open up and test the drive motor.
When I got this far, I stopped diagnosing. All that seems left to fail is the water inlet valve.
What is your advice for the next steps? Thanks!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,905 posts
  • Flavorite Brew:Killians Red
Posted 16 November 2011 - 05:20 PM
Sounds like 2 problems...optics appear ok based on solid lite when flap held in...not frozen in fill tube (string test)...only thing left is inlet valve...easy test...go to the valve and using a cheater cord (careful now!) And connect 120vac directly to the I/m valve...
if water flows, valve is good. If not bad valve.
will need a meter to test auger motor inside frezzer door (see access panel?)
check the two innermost wires on the plug for 120 vac while a helper holds the door switch and pushes the cradle switch.
voltage present? Bad auger motor.
    Shōgun
  • Master Samurai Tech
  • 30,403 posts
Posted 16 November 2011 - 06:06 PM
Part links:
Augur motor ==> Drive Motor
Water inlet valve ==> Water Inlet Valve
#4 bigbigtex
bigbigtex
  • 3 posts
Posted 17 November 2011 - 12:57 AM
KurtiusInterupptus -
1. do you have a instructional webpage for the two tests you mentioned? (I do have a voltmeter to use.)
2. Are you saying the control module is needing replacing or is it still inconclusive until I do water valve test?
Thanks!
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 November 2011 - 01:08 AM
measure for 120v AC between L and N on IceMaker Module
Is there Ice already in the IceMaker Mold ?
#6 bigbigtex
bigbigtex
  • 3 posts
Posted 17 November 2011 - 11:40 AM
There were small slivers of ice in the molds... maybe a tenth of full sized cubes.
