GE gas range M#JGBS23BEA2CT gas valve whining
22 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
  • Flavorite Brew:Guinness Stout
Posted 16 November 2011 - 06:50 PM
The whining on this GE gas range M#JGBS23BEA2CT starts shortly after the gas lights. The whining comes and goes. What can do about this; is there a FixitNow article on this?
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 16 November 2011 - 06:59 PM
After reading our appliantological shogun's post here (http://fixitnow.com/...ir-oven-repair/), I recognized my range problem. The "booms" aren't as dramatic, but they are there (cursed Nokia Surge from which I can't upload video). My customer's gas valve is less than a year old, though. Call in the warranty from Good Enough (GE)?
Mr. Tyrus Lee Smith
706-778-3411
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 16 November 2011 - 07:14 PM
Is this on surface burners or oven? Sounds like a gas pressure adjustment is needed. LP or NG?
#4 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 16 November 2011 - 08:32 PM
The whining occurs in the bake compartment, and the oven uses natural gas.
Mr. Tyrus Lee Smith
706-778-3411
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 November 2011 - 10:40 PM
weak (or wrong) Oven Ignitor ?
(should be flat, not round)
measure amperage ...
click on picture
#6 jumptrout
jumptrout
  • 1,382 posts
Posted 17 November 2011 - 06:55 AM
What color are the flames and tips?
Are the flames lifting from the base of the burner tube?
Is the gas cock turned completely on?
Is any soot being created?
#7 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 17 November 2011 - 10:01 AM
Sensei Reg, I installed a new, flat OEM igniter two months ago.
The flames emit from the bake arm, and are mostly (i.e. 85% of the time) blue. There is a flame coming from the front, underside of the bake arm. I didn't turn the gas cock on; my partner did. There was soot before I replaced the gas valve two months ago, and there still is soot in the broil area.
Mr. Tyrus Lee Smith
706-778-3411
#8 jumptrout
jumptrout
  • 1,382 posts
Posted 17 November 2011 - 10:29 AM
I would remove,clean and inspect the bake burner. What you are describing sounds like a gas pressure or restricted gas flow problem. After cleaning the burner the air shutter needs adjusting for the optimal flame color. Pay attention to the burner where you see flame underneath. The burner may have a hairline crack. You may also need to adjust the nozzle on the gas valve.
#9 RegUS_PatOff
  • 33,588 posts
Posted 17 November 2011 - 12:36 PM
so... the Ignitor and Gas Valve have been replaced ?
Has this Oven worked OK up till now at this location ?
#10 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 17 November 2011 - 03:27 PM
No, I've replaced one other igniter at the first of the year.
Jumptrout, where's the air shutter and how do I adjust it?
Mr. Tyrus Lee Smith
706-778-3411
#11 jumptrout
jumptrout
  • 1,382 posts
Posted 18 November 2011 - 07:36 AM
Look where the burner tube attaches at the gas valve nozzle. The air shutter is at the base of the burner tube.
#12 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 24 November 2011 - 10:34 AM
Speculation can cease, for the moment; the bake arm (http://www.repaircli...er=JGBS23BEA2CT) contains a pencil-eraser-sized hole at the igniter.
Mr. Tyrus Lee Smith
706-778-3411
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 24 November 2011 - 05:24 PM
That'll do it!
#14 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 23 March 2012 - 07:10 AM
Here we go again. After some passive-aggressive complaint about "...I could've had a NEW range for what I've put into this one," the customer calls back.
I get there, pull the bake cover, and turn on the "BAKE" knob to 350. After a little over a minute, I hear a low volume, high pitch whine over the burning of the LP gas. The whine goes away once the temperature sensor is satisfied, and the gas valve closes.
The gas valve, bake arm, and hot surface igniter ALL have been replaced...what's next?
Mr. Tyrus Lee Smith
706-778-3411
#15 jumptrout
jumptrout
  • 1,382 posts
Posted 23 March 2012 - 07:35 AM
One post you said "NG" another you say "LP"?
#16 jumptrout
jumptrout
  • 1,382 posts
Posted 23 March 2012 - 07:41 AM
Have there been any adjustment to the orifice hood on the gas valve?
#17 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 24 March 2012 - 06:53 AM
The range uses LP gas. Where on this image (http://www.repaircli...er=JGBS23BEA2CT) is the orfice hood?
Mr. Tyrus Lee Smith
706-778-3411
#18 jumptrout
jumptrout
  • 1,382 posts
Posted 24 March 2012 - 07:25 AM
It is the part the gas burner goes over.
Adjustable with a 1/2 inch wrench.
CW for LP ccw for NG.
The air shutter is at the base of the burner tube that goes over the orifice.
#19 jumptrout
jumptrout
  • 1,382 posts
Posted 24 March 2012 - 07:29 AM
Has the regulator been set for LP?
#20 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 970 posts
Posted 25 March 2012 - 07:42 PM
"CW for LP ccw for NG..."? Jumptrout, where is the regulator, and how will I know it has been set for LP?
Mr. Tyrus Lee Smith
706-778-3411
