Amana Washer DLW330RAW: Smoke!
3 replies to this topic
#1 Bob
Bob
    Ikkō-ikki
  • 38 posts
Posted 17 November 2011 - 02:01 PM
Ok, I started a small load of laundry and a few minutes later smelled smoke! I ran downstairs and the washer was smoking. I don't recall if it was agitating or not, I believe there wasn't any noise at all--it appeared to be stalled with smoke pouring out. But, I confess I was in emergency mode, so my recollection for detail is probably unreliable.
I quickly killed power, unplugged it, turned the dial to off and threw the lid open... smoke roiled out. The tub had not drained. I opened windows and used fans to clear the basement. The stench was incredible! I thought it was electrical fire smell, but now think it might be rubber, perhaps from the belt.
I pulled the lower panel off and didn't notice any obstructions or any damage. Everything appeared clean and intact. I was able to move the pulleys, tensioner and belt fairly easily. The and pulley grooves and belt seemed ok. I am able to deflect the belt by pressing on it: it is neither loose or super tight. I think I replaced the belt last year....but, my wife runs the crap outta the washer. There is definitely some belt dust.
I decided to run it through the rest of the cycle and watched it the entire time (laying on the floor with safety glasses, a flashlight and a HEPA mask): it seemed fine.
I checked for obstructions between the inner and outer tub by pulling the top ring off and agitator out, and there was nothing there. Could there be something between the inner/outer tub but under the inner tub? Not sure how to get the inner tub out.
I am now very nervous about this machine! Any ideas as to what could be wrong?
Many thanks,
Bob (sipping a Michelob...yeah, kinda whimpy, but I'm a cheap date)
Edited by Bob, 17 November 2011 - 02:57 PM.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 17 November 2011 - 06:26 PM
Maybe check for goodies in the drain pump
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 17 November 2011 - 06:49 PM
Please send pictures....................(laying on the floor with safety glasses, a flashlight and a HEPA mask):
#4 Scottthewolf
Scottthewolf
    Senpai
  • 2,966 posts
Posted 17 November 2011 - 10:30 PM
Almost sounds like the tub bearing and seal going bad, that's what these do when they go bad before it starts sounding like a jet plane taking off.
Scott Wolf
