Bosch SHX46A05UC/14 Making Sound and not Pumping
17 replies to this topic
#1 drf255
drf255
  • 14 posts
  • Flavorite Brew:NY
Posted 20 November 2011 - 08:21 PM
My Bosch DW has a humming/motor running sound from the bottom left side front. I noticed if I shut it down and then turn it back on, the normal pumping sound will start again for approximately 5 seconds, then the pumping stops and the humming starts again.
When I open it, its hot, and I see a small amount of water coming out of the top sprayer. The bottom is full of water.
Any help appreciated. Thanks.
#2 kdog
    RoughShod
  • 7,465 posts
Posted 20 November 2011 - 08:28 PM
Something is either jamming your drain pump, or the pump has failed
http://www.repaircli...SHX46A05 UC/14 (FD%208211-)
#3 drf255
drf255
  • 14 posts
  • Flavorite Brew:NY
Posted 21 November 2011 - 05:09 AM
It's listed as discontinued. Is there a replacement part, and where is it located/ how do I get to it?
#4 kdog
    RoughShod
  • 7,465 posts
Posted 21 November 2011 - 02:45 PM
Hmmm, so it is - not sure what's up with RepairClinic's crossover info, This one awtta work for you:
http://www.repaircli.../642239/1387293
Did you look for obstructions in pump and/or drain hose (no kinks) ?
    Shōgun
  • Master Samurai Tech
  • 29,365 posts
Posted 21 November 2011 - 07:29 PM
Odd, indeed! Not sure what's going on with that. I looked it up by model number using the parts search box at the top of the page and got the first discontinued part you posted. Good find on that uddin'! Howz you find that bad boah?
