Asko 7005 dryer won't spin; rear is HOT
#1
Posted 20 November 2011 - 11:48 PM
Has anyone run across this before? Just making inquiries before pulling the machine apart....
#2
Posted 21 November 2011 - 07:36 AM
#3
Posted 21 November 2011 - 10:33 PM
Does anyone know what the resistance should be across the motor terminals? I get continuity across all three....
#4
Posted 21 November 2011 - 10:36 PM
How many Ohms ? any continuity to Ground from any of them ?
#5
Posted 21 November 2011 - 10:53 PM
I checked repairclinic.com for a replacement, just in case. Doesn't appear to be the same motor; mine has the start capacitor mounted separately while the version on the website has it on the motor.....
#6
Posted 22 November 2011 - 12:07 AM
22-50 ohms across the terminals
What about the other pair ? a reversible split phase would have 2 windings more or less the same, so 2 of the pin combinations should roughly add up to be the third in which case you don't likely need a motor anyhow. Try turning the motor by hand in both directions
#7
Posted 22 November 2011 - 11:13 PM
55 ohms from L2 to common
34 ohms across the hot leads
I tried to test the starting capacitor with my digital multimeter. Ambiguous results...so I reconnected the motor leads, plugged in the dryer, and tried starting the motor by hand. It just hums....
#8
Posted 23 November 2011 - 12:48 AM
More on capacitor testing: http://www.applianto...__1#entry168814
http://www.applianto...otor-capacitor/
#9
Posted 23 November 2011 - 08:21 AM
No blower obstruction...no belt...no start=bad motor.
#10
Posted 23 November 2011 - 08:46 AM
- kdog likes this
#11
Posted 03 December 2011 - 02:16 PM
#12
Posted 18 December 2011 - 07:42 PM
I read somewhere that they don't put grease fittings on bearings for these small electric motors because they calculate by the time they'll need additional grease they'll be worn out anyway. My view on the matter is....if they still work, they're still good......
I also figured out a less painful way to get the &^%*#$#! belt back on the drum....if anyone's interested let me know and i'll share.
Edited by rwfisher, 18 December 2011 - 09:28 PM.
