gflansaas
Maytag Neptune MAH6500AWQ dreaded "LR" code
7 posts in this topic
arggggggg!!!!
oh wise one,
started having intermittent occurences of the LR code and machine not spinning. occurences increased now to no agitate as well. opened up the machine and found the diag instructions.
NO burnt areas on either board. ( no fuse on motor control board)
Motor ohms out OK
always 120v at connector on MCB
all diag tests resuts are again intermittent
Spin cycle
quick cycle
Have checked all neutral wire connectors.
always here a relay click on the upper board and then followed by click on MCB. sometimes the motor then does its job and sometimes not.
QUESTION:
these results point me to the MCB???
is board and motor from MAH5500 interchangeable
SER #37830974GA
MCB # 6 2726410
thats easy for you to say.....
is board and motor from MAH5500 interchangeable???????
my info
SER #37830974GA
MCB # 6 2726410
... is board and motor from MAH5500 interchangeable???????
depends on model & series numbers
TCL-0014-B.pdf
service bulletin is unclear. I have provided my model and serial and MCB # so what do i order just the board or motor & board??
I have and it says to call to verify ser #'s...just trying to do it thru this forum, as the service bulletin indicates based on my parts that they need to be ordered seperately.
it appears mine are already the new type
