Whirlpool Gas Dryer WGD5840SW0 wont heat
igniter coil fuse flame
6 replies to this topic
#1 Pio Egan
Pio Egan
  • 4 posts
  • Flavorite Brew:guinness
Posted 23 November 2011 - 11:29 AM
Hello, Dryer drum turns. Igniter will not glow. Replaced the igniter, no glow. All fuses show continuity. Do not get 120V on either coils. coils show resistance.
thanks.
Pio
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 November 2011 - 01:05 PM
... All fuses show continuity.
including #15 and #25 on the Heater Box ?
check for 120v AC (to chassis, ground) from each side of each of the (3) Thermal Devices
#3 Pio Egan
Pio Egan
  • 4 posts
Posted 23 November 2011 - 02:08 PM
Thanks for the quick reply Grand Master. Thermal fuse beside the blower, #15 and #25 all have continuity. Will check the voltage later today. Could it be control card?
#4 RegUS_PatOff
  • 33,588 posts
Posted 23 November 2011 - 03:04 PM
.... Could it be control card?
no,
possibly the Timer
OR
the Heat (ON/OFF) Switch
#5 Pio Egan
Pio Egan
  • 4 posts
Posted 23 November 2011 - 04:29 PM
Checked for 120V on each side of the (blower fuse?) in the exhaust manifold. 120V on one side but not the other. Fuse was bad. I removed the exhaust casing and cleaned it out well. I temporarily joined the wires together and the burner lighted. I put everything back together except the back cover. I started the dryer on high and looked through the peephole, the igniter lighted the gas and everything worked fine for 3 or 4 minutes then the fire went out. I cycles back on again after a few minutes. The drum runs fine. Is this normal?
#6 Pio Egan
Pio Egan
  • 4 posts
Posted 23 November 2011 - 04:58 PM
Grand Master, Cycling thermostat and thermal fuse ordered. Thank you much..
#7 RegUS_PatOff
  • 33,588 posts
Posted 23 November 2011 - 06:01 PM
Thermal Fuse and High Limit Thermostat
http://www.repaircli...?R=154&N=940740
... cycles back on again after a few minutes. The drum runs fine. Is this normal?
normal,
but also
check your Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
