GE fridge TFX22ZPDA ice dispenser stopped working
ice maker
5 replies to this topic
#1 victorsmiller
victorsmiller
  • 3 posts
Posted 25 November 2011 - 12:19 PM
Starting about a week ago my ice maker stopped making ice. I emptied out the bin and replaced it, but noticed that the wire arm is not all the way down (only about 1/2 way) and I can't get it to go down anymore. I have water supply. The cold water comes out at its usual anemic flow. I popped off the front and checked the gears which look ok. Nothing appears to be stuck in the ice maker. I remember something similar happened about 1 1/2 years ago, and after letting it sit for a few weeks it started working again. I'd like something a little more proactive than that!
  • 24,312 posts
Posted 25 November 2011 - 01:10 PM
Sounds like you be needin one o' deese ==> http://www.repaircli...0X10093/1399596
#3 victorsmiller
victorsmiller
  • 3 posts
Posted 25 November 2011 - 02:05 PM
Thanks, I'll defer on that. After fiddling around with icemaker to see if I could jog something loose, I just looked at it again, and now the arm is all the way down. Something that I couldn't see (ice?) must have been in the way. I'll wait a day to see if it starts to produce ice.
#4 Comstock_Services
Comstock_Services
  • 462 posts
Posted 26 November 2011 - 01:14 AM
If your Ice maker stops producing ice, at any point, that is usually a sign of failure, within the ice maker itself. you can remove the ice maker, its only 3 screws and a wire connection.
#5 victorsmiller
victorsmiller
  • 3 posts
Posted 26 November 2011 - 06:22 PM
The icemaker is working again. The problem is that something was blocking the wire arm preventing it from going down all the way. It eventually went down by itself Could it have been a piece of ice that was blocking it? I couldn't see anything.
#6 Comstock_Services
Comstock_Services
  • 462 posts
Posted 26 November 2011 - 06:28 PM
yes that is possible.
