KAWS750LQ0
10 replies to this topic
#1 dscanlon
dscanlon
  • 4 posts
  • Flavorite Brew:Diet coke
Posted 26 November 2011 - 11:36 PM
My washer was leaking, so I replaced the pump. It failed to spin, so I replaced the coupler and the lid switch. It still hums when on the spin cycle. I took it apart, and the motor will only turn if I help it get started. If it is still moving, even slightly, when turned off, then on again quickly, it will continue to run without issues. If it comes to a complete stop, then it needs help to get going again. Do I need to replace the motor, or should I just give up and grab a cheap washer off Craigslist?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 November 2011 - 11:48 PM
Does the Motor start & run OK during Agitate ?
#3 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 27 November 2011 - 12:08 AM
cant find that model number, but since you mention
I ASSUME that this is a direct drive washer. I would say that if you already have put a pump, coupler, lid switch, into it, then it des not cost that much more for a motor.
Some of these units have a cap, and some of them have trouble with a loose neutral wire too, there are a few things to check first.
http://www.repaircli...tor/3350418/157
#4 dscanlon
dscanlon
  • 4 posts
Posted 27 November 2011 - 07:07 PM
It is a direct drive Kitchenaid washer. It does the same humming noise during agitate, and the motor only spins clockwise once I help it get started.
#5 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 27 November 2011 - 09:02 PM
were, you able to check the wiring connections, to the motor?
#6 RegUS_PatOff
  • 33,588 posts
Posted 27 November 2011 - 09:10 PM
KAWS7050lQ0
can you check that model number again ?
#7 dscanlon
dscanlon
  • 4 posts
Posted 28 November 2011 - 08:30 AM
Sorry, I put an extra 0 in the model #- it is actually KAWS750LQ0. I am not able to check the wiring connections to the motor (I'm lucky to have the right screwdrivers to do the job). I have not tested the motor with the tub full of water while the motor is connected.
#8 certified tech group 51
  • 2,670 posts
Posted 28 November 2011 - 09:45 AM
With the outer cabinet removed , do you see a ring of discoloration about 12 inches off of the floor on the inside of the cabinet?????? If there is, it appears it is a slipping clutch. The top seal on gearbox is leaking OR..... water is migrating down from a tub seal or seals at the spin tube/support tube...keep us posted
#9 dscanlon
dscanlon
  • 4 posts
Posted 30 November 2011 - 02:19 PM
There are no rings of discoloration on the cabinet. Trips to the laundromat are adding up (5 kids)!
#10 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 30 November 2011 - 05:27 PM
the model # is actually KAWS750LQ0.
Corrected title
#11 kdog
    RoughShod
  • 7,474 posts
Posted 30 November 2011 - 05:32 PM
Check all of the wires that terminate at the motor plug connector for loose/burnt connections - some resistance/voltage measurements may be required at motor/capacitor etc.
