Miele T7644C Tumble Dryer - dead control panel
24 replies to this topic
#21 philmang
philmang
    Ikkō-ikki
  • Chief Appliantologist
  • 20 posts
  • Flavorite Brew:cristal
Posted 28 January 2012 - 10:00 AM
Have been checking further on the wiring diagram. I have found that 220V is present on the Control Board at connector ST1. It them goes through various components but I do not have it on the On/Off Switch. I can only conclude that I have a faulty Control board at this stage. I have attached a link with images of the control board in case anyone may have a flash of inspiration.
https://picasaweb.go...CJKL3JKNsruPrgE
#22 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 28 January 2012 - 04:44 PM
You should see the voltage across the switch if it is turned off - I haven't seen a board like that one, but if you're getting the voltage to it and it fails to function it would be most suspect.
BTW - Nice Photo's
#23 philmang
philmang
    Ikkō-ikki
  • 20 posts
Posted 09 February 2012 - 01:52 PM
Hi Guys just wanted to say a thank you for all the help on this . Great to be able to get the manuals and advice. Suspected the control board and managed to get a company in the UK which repairs all kinds of PCB boards. An to my great relief they have managed to repair for a cost of £50 . A long away from close to €300 from Miele. I am just waiting to get the board back and hopefully that should be it. I will let you know if I am successful. Once again thank you for all the help.
#24 philmang
philmang
    Ikkō-ikki
  • 20 posts
Posted 24 February 2012 - 10:32 AM
Guys just wanted to close out this post. with a final thank you for all the help. The repaired PCB Board arrived back and the machine is now back functioning as normal. Many thanks once again.
#25 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,409 posts
Posted 24 February 2012 - 10:42 AM
Domo for the update, Phil! :thumbsup:
