lg dlex7177rm
#1
Posted 27 November 2011 - 04:35 PM
#2
Posted 27 November 2011 - 04:43 PM
Can you turn the Drum ?
How's the Belt ?
Can it be re-started (more hum) right away ?
#3
Posted 27 November 2011 - 07:09 PM
- Samurai Appliance Repair Man and kdog like this
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#4
Posted 27 November 2011 - 08:06 PM
#5
Posted 27 November 2011 - 08:34 PM
Looking at the rear of dryer---the TOP COVER has what looks like "hinges"
At each plastic "hinge"---there are 2 phillips-type screws---remove only the lower screws at each "hinge".
Grasp the TOP COVER and slide rear about 2 inches---lift off & remove.
Standing at the front of the dryer---remove the WATER DISPENSER TRAY (release tab is at the bottom of the drawer).
Remove the 2 phillips screws that are now visible with the WATER DISPENSER DRAWER removed.
At the right-hand side of the CONTROL PANEL---remove a single phillips screw from the corner (opposite side of panel).
Disconnect plugs/wires that are directly behind the *jog dial* of the CONTROL PANEL
Remove the CONTROL PANEL---a small flat screwdriver helps to unsnap the **tabs** that secure the CONTROL PANEL
With the CONTROL PANEL removed---remove the 5 screws which secure the entire FRONT PANEL/COVER of the dryer. These screws are located at the top of the front panel---and were not visible with the CONTROL PANEL installed.
Pull the FRONT PANEL towards you just enough to allow unplugging the DOOR SWITCH
Lift the entire FRONT PANEL an inch or so & remove
Remove the LINT FILTER & place it inside the Drum
Looking at the front of the dryer---you'll notice a DUCT HOUSING (silver)
Remove the 2 phillips screws from the DUCT & slide it down-and-away.
With a bright flashlight---examine the BLOWER HOUSING---remove any clothing/obstruction
Re-assemble in reverse order
Edited by john63, 27 November 2011 - 08:42 PM.
- Samurai Appliance Repair Man, kdog, Comstock_Services and 1 other like this
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#6
Posted 03 December 2011 - 11:30 AM
#7
Posted 03 December 2011 - 12:38 PM
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
How to disassemble an LG dryer to remove a sock or something stuck in the blower
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 December 2011 - 02:56 PMA quick test to see if you have a drum blockage problem is to simply open the door and try to turn the drum by hand. If...
Read Full Entry →
