Leaking from vent...LG Tromm M/N:WM2077CW
#1
Posted 27 November 2011 - 05:10 PM
Well my LG washer leaks water during the spin cycle...actually water just pours out from the vent. I've read about a valve that supposed to close during the spin cycle, but can't find any other information about correcting or fixing thiss problem. Any and all help will be greatly appreciated. Thank-you in advance.
#2
Posted 27 November 2011 - 05:15 PM
#3
Posted 27 November 2011 - 07:08 PM
May have a sticky/stuck MUSHROOM VALVE (or missing altogether).
Looking at the rear of the washer---the top cover has 2 phillips-type screws per side.
Remove both of the *lower* screws.
Slide the top cover rearward (may take considerable effort) about 2 inches.
Lift top cover & remove.
You'll notice a black rubber bellows type hose near the top/center of the washer---loosen the band clamp on the *tub* and pull off the hose.
There should be a dome-shaped cap (MUSHROOM VALVE) in the round hole (replace if missing).
The MUSHROOM VALVE should slide up & down freely---if sticky---replace with a new valve.
Most leaks at this AIR VENT are caused by overuse of "HE" type detergent or incorrect type detergent.
- Samurai Appliance Repair Man, kdog, Comstock_Services and 1 other like this
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#4
Posted 27 November 2011 - 11:30 PM
I'd removed the cover prior to posting and I didn't notice any "mushroom valve". Tried looking up this piece but can't seem to locate yet. But thank-you for this information. Now I know where to look and what to look for.
Don
#5
Posted 27 November 2011 - 11:40 PM
http://www.repaircli...ER4001A/1268531
Edited by john63, 27 November 2011 - 11:48 PM.
- Samurai Appliance Repair Man and jumptrout like this
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
Also tagged with one or more of these keywords: Leaking from vent
Appliantology Appliance Repair Forums →
The Laundry Appliance Repair Forum →
LG WM2277HW washer leakingStarted by Comstock_Services, 03 Jan 2012 |
0 members, 1 guests, 0 anonymous users
