Learn how to be your own tech line...
FathersBest
Refrigerator Repair Sub Zero Model 532
7 posts in this topic
My fridge and Freezer are both functioning but the center separation between the Beer Cooler and the freezer goes from warm to hot and back. The compressor seems to be always on, never takes a break. I've been told to take apart the freezer but I'm not sure just how to go about that. I've also been told that I can't get parts for the Sub Zero and feel like I'm shut out of fixing it myself. This all started when I noticed that my fridge was losing temperature, so we vacuumed the coil area and it became cool again right away. I can be mechanical and don't have much to spend fixing this monstrosity. Can anybody help?
The refrigerant lines run between the separation to reduce exterior moisture. It is normal to get hot.
The part in between the fresh food section and the freezer section is called the 'stile' ....Refrigerant lines run from the condenser coils down to the drain pan in this 'stile'.....It has been called a 'stile heater' or correct name a 'mullion heater'. The tube assy is a 'yoder loop' ....... it should not be 'hot', ( too hot to touch ) it should be warm or a bit above warm....Put your cheek to it, nice and cozy warm or did you just brand your self???..I would first check the condenser fan motor, spinning nice and about 1300 R.P.M.???? If motor is sluggish or will not start every time , up date the motor This is what draws cool air thru the coils to keep the refrigerant from basically baking your compressor... ( Which in turn will shift your 'super heat ' zone and you do not get the correct temp of refrigerant to the evaporator coils ) ....You do not need a Sub-O motor, you need one with a 'foot mount' ( 51 frame ) ....like p/n 61021 or 65211 or 65411 depending on the motor R.P.M. keep us posted..
Edited by certified tech group 51
love this ultra-high tech diagnostic tool, CTG! actually this is very a accurate way to determine if the cond. fan is working properly. LMFAO!
The fan and motor that I am to check is above the fridge/freezer, behind a shield, correct? How will I know that it isn't functioning properly? Should I just replace this motor? I really appreciate your help!
Condenser Fan
On top of Fridge, on right side of Compressors
You are lucky to have this unit in the home to keep an eye on it....Remove the top grill and the panel, put some eyes on the motor....If my wire schematic is correct, your condenser motor should be running all of the time......You have your own tech sheet attached to the panel to the left, yellow envelope.....Is the motor hot to the touch, no need to put your cheek to it, tried it once and my hair got caught in the small whirling blade... :silly: ......motor will be warm from the hot air from the condenser coil..... Has the compressor operation changed since you vac'ed the coils..???? If every thing is hunky-dory with the condenser motor we will move on to removing the fresh food evap panel...But no need to rush, some times it takes up to 24 hours or so for the system to bring the refrigerant down to operating temps.....I.E. kitchen temps, door openings....warm food stuff....P.S. do you have a thermometer in the fresh food section ?? Temp.is _____?
