jahjahbinks
dacor double oven cps227 stops running
4 posts in this topic
i have a dacor cps227 double oven that won`t run both ovens at the same time the main relay board was replaced to correct the F1 constance beeping ,worked for 1 day and returned now the problem is both ovens won`t work at the same time (one oven just shuts off) then F1 again the upper oven according to the service chart f1 is element relay circut failure, (replaced 1 week ago) @$200+ , each oven will work one at a time but not together the only code is F1 what am i missing? no help from dacor (not suprised)
question #2 if it takes 2 men to test this machine ? why keep it ?
Need to check the power junction box where then wall oven connects to house power. If there's an aluminum-copper junction in the junction box, that will become a high resistance connection over time and smokes the common terminal on the main relay on the board. The problem will continue to occur until the connection is corrected.
1 person likes this
o.k thanks. will give them a try and report back.
