Kenmore dryer 70 series mod.# 110. 667 52 500
Kenmore Dryer
8 replies to this topic
#1 Ronbo
Ronbo
  • 3 posts
  • Flavorite Brew:Bud
Posted 11 October 2011 - 06:50 AM
I have a Kenmore 80series dryer that heats up so hot you can barely touch the clothes.Funny thing though is it's only when the clothes are pretty much all dry.It does it on the cool air setting also.It has a auto moister sensor on it and leaning in that direction but would appreciate any input.
#2 RegUS_PatOff
  • 30,688 posts
Posted 11 October 2011 - 10:37 AM
model number ?
110.xxxxxxxx
sounds likea Heating Element that is partially shorted to chassis (ground)
#3 Ronbo
Ronbo
  • 3 posts
Posted 12 October 2011 - 07:08 AM
model # 110 62802102
  • 24,694 posts
Posted 12 October 2011 - 08:06 AM
Here's how to test the heating element:
Here's how to replace it:
And here's the part link ==> Heating Element Assembly
#5 Ronbo
Ronbo
  • 3 posts
Posted 29 November 2011 - 02:34 PM
Dryer quit heating and the dial wasn't moving-so I replaced the heating element, as advised on here. It heats well for about 10 minutes , then stops heating . I have found that unplugging and plugging it back in ,that the heating element works again then stops after 10 minutes .
  • 24,694 posts
Posted 29 November 2011 - 03:19 PM
Just the heating element stops working or does the motor stop running, too?
If just the element, then it sounds like the element is cycling on and off on the high limit thermostat because the cycling thermostat is stuck closed. So the heating element stays on until the high limit is tripped and then it takes a while for it to cool down. I think the unplugging and plugging it back in back be coincidental.
Part link to the cycling thermostat ==> http://www.repaircli...er=110.66752500
#7 RegUS_PatOff
  • 30,688 posts
Posted 29 November 2011 - 04:35 PM
.... It heats well for about 10 minutes , then stops heating .
... that may be normal, depending on Vent temperature
If you could check the temperature at the Dryer Vent:
and check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#8 kdog
    RoughShod
  • 7,433 posts
Posted 30 November 2011 - 12:28 AM
Just for the record, you were advised to TEST the element, long dry times are 96.8 percent venting issues.
Topics merged
#9 RegUS_PatOff
  • 30,688 posts
Posted 30 November 2011 - 01:10 AM
Topics merged
... i think that was for a different model number :whistling:
