no power to LG WM0532HW washer
power LG washer
1 reply to this topic
#1 jonsmilburn
jonsmilburn
  • 1 posts
  • Flavorite Brew:Shiner Lager
Posted 29 November 2011 - 09:30 PM
LG Washer not getting power at all. No lights on the control panel. Circuit was blown, but when I reset it, the control panel was still not lighting up. No response to pushing the power button at all. I checked the outlet with a lamp and it's working. Does this model have a reset button somewhere? Thanks, Jon
#2 john63
john63
    Dean of LG Appliantology
  • 2,152 posts
Posted 29 November 2011 - 10:51 PM
Most likely a failed MAIN BOARD.
To verify---remove three phillips-type screws from the top of the CONTROL PANEL
Pull the CONTROL PANEL towards you.
Locate the ELECTRICAL NOISE FILTER (small electronic board 4 1/2" by 2")
Pull the *white* plug from the Noise Filter
Using a multimeter---place the test leads into the *white* plug (not the Noise Filter)---if 110-120 volts AC is shown---this verifies power to the washer.
Reconnect the *white* plug to the Noise Filter
Pull the *red* plug from the Noise Filter
Place the test leads into the *red* plug connection of the Noise Filter (not the wire/plug itself)---if 110-120 volts is shown on the
meter---the NOISE FILTER is undamaged & "good".
Replace the MAIN BOARD (6871ER1023Q)
If *no* voltage was detected at the *red* plug connector on the Noise Filter---replace the MAIN BOARD and the
NOISE FILTER (6201EC1006A)
http://www.repaircli...ER1023Q/1359883
http://www.repaircli...ber=6201ec1006a
Edited by john63, 29 November 2011 - 10:52 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
