squealing Estate TAWS700EQ2 direct drive
drain pump estate noise
20 replies to this topic
#21 mike_samurai
mike_samurai
  • 11 posts
Posted 06 December 2011 - 10:21 PM
OK,
I think it is now fixed. The coupling needed to be pounded flush on the transmission input shaft. The coupling was effectively 1/4" too long, thus putting axial load on the motor...and bearings... thus making the bearings squeak and the motor work too hard.
We are up and running. I did probably take a bit of the motor's life away with that stunt.
For your general knowledge.
Also tagged with one or more of these keywords: drain pump estate, noise
