GE WDSR2080d Won't spin (or fill)
10 replies to this topic
#1 mrhudock
mrhudock
  • 4 posts
Posted 30 November 2011 - 09:23 PM
Afternoon!
I tried to be as detailed as possible in order to narrow down the issue easily.
Basically, went to put wash into dryer and it was soaking wet.
The water seems to have drained because the clothes are just wet, but the machine will not go into "Spin Cycle"
The lid switch seems to work no problem because the machine DOES agitate when the lid is closed.
Also, another part of this problem is that now when I turn the dial to try and start it "as in to turn on the water to start a load" it automatically goes into agitate.
It's almost as if it thinks its full of water. I read a post earlier on another site but can not find it. It said that this brand of washer determines if its full of water with a tube and that it may be blocked, which causes it 1) to not spin because it thinks its full of water & 2) not fill because it thinks its full of water as well.
Does this sound true?
I have the front of the machine off, and I looked all around, but I don't see what hose they are talking about.
I do see their is a little bit of water in the reservoir that appears to be right above the tube for the pump, but when the machine is on that water disappears..... This little bit of water appears to be below the basin level.
**UPDATE**
So, I realized that the pump was pushing the water through the pump and into the hose.. so I took the outlet hose and put it very low level, turned the washer and viola the water in that little reservoir pumped out. However, I question whether or not this was ever even a problem.
However, the pump still continues to make the "chuga chuga chuga chuga" sound and will not begin the spin cycle.... Is it possible that the inlet on the pump is still clogged even though it allowed the remaining water to pour through? Or does it sound more like the water level sensor/tube/switch is malfunctioning and that reservoir of water normally is filled?
Any suggestions please let me know
Thanks a Ton!!!!!
- Josh
#2 RegUS_PatOff
  • 30,190 posts
Posted 30 November 2011 - 10:23 PM
... GE WDSR2080d
... I tried to be as detailed as possible in order to narrow down the issue easily.
depending on the missing characters at the end of your model number
would determine if you have the standard Motor OR the Inverter Motor
#3 mrhudock
mrhudock
  • 4 posts
Posted 01 December 2011 - 07:16 AM
Sorry, it is as GE WDSR2080daww
#4 RegUS_PatOff
  • 30,190 posts
Posted 01 December 2011 - 09:15 AM
... it is as GE WDSR2080daww
... OK, not an Inverter Motor, but I'm not a Master on that model
maybe one of the other Masters on here are ...
#5 kdog
    RoughShod
  • 7,428 posts
Posted 01 December 2011 - 08:28 PM
Laying the hose down will always allow water to trickle out, it's supposed to be raised - that's not your issue.
It is possible that the Waterlevel Switch has failed, or the tube/chamber is plugged. should be on the rear of the outer tub, r.h. side. Easier to see if you remove the console facia (4 screws along top), tube connects to switch in console - follow that.
Hey, Brutha, can you spare a dime for a cuppa joe ? http://web.me.com/zenzoidman/kdog/
Le Chien Rouge
#6 RegUS_PatOff
  • 30,190 posts
Posted 01 December 2011 - 10:55 PM
should Spin without Water Level Switch functioning.
Sounds Like a bad Timer (or wiring)
#7 kdog
    RoughShod
  • 7,428 posts
Posted 01 December 2011 - 11:26 PM
W/L switch could be "stuck" in the full position
Le Chien Rouge
#8 mrhudock
mrhudock
  • 4 posts
Posted 02 December 2011 - 05:51 AM
Thanks for all of the great replies. Thankfully that is all it was. Just the "Switch" was stuck. I just rotated it back & forth 3-4 times and it filled and spun no problem.
What a simple free solution!!!! lol If only everything in life would be that easy when it breaks.
Thanks again!!
Josh
#9 RegUS_PatOff
  • 30,190 posts
Posted 02 December 2011 - 07:20 AM
... Just the "Switch" was stuck.
what Switch ?
#10 kdog
    RoughShod
  • 7,428 posts
Posted 02 December 2011 - 03:00 PM
This one:
http://www.repaircli...er=WDSR2080DAWW
Le Chien Rouge
#11 mrhudock
mrhudock
  • 4 posts
Posted 03 December 2011 - 02:34 PM
Just the switch mounted right on the top, that says Small Large Super... just turned the dial back and forth a few times :)
